Music on Hold Problem in IVR
Fede
Italy
Hi to all,
I'm having this issue with music on hold.
If I set in the IVR "Ring Back" to the custom Music on Hold (local) on hold it plays always the Default music on hold.
How can I cange this behaviour?
Thanks a lot!
Assuming you selected something other than default MOH in the drop down, double check what is in the dial plan for your IVR.
Dial Plan>Dial Plan Manager> find dial plan for IVR in question. Usually close to order 100.
Click to view dial plan then click the XML box in top right.
Check the line with "transfer_ringback=..." to verify it shows correct music source.
If correct, flush your cache. If it is incorrect, it could be a bug that needs to be reported.
Thanks a lot for your reply!
In fact is default: <action application="set" data="transfer_ringback=local_stream://default"/>
And if I edit IVR it shows that I have selected another music
I have not the last version of Fusion cause last time I tryed to Update I was no more able to reach the web page. Any advice to update?
Thanks!
