No Audio when we switch Network on live call with 4G Failover Router
puneet936
14
Example I have 4G Failover router whenever i am on live call if i switch network from Wan-1(Wire Broadband) to 4G we are not getting Audio Means RTP issue due to WAN IP Change so does anyone know how to solve this issue ? while you are on live call we have to make sure call will not get disconnect and it will continue with very little half second of disconnect.
FYI.when i m disconnecting my Wan cable i am monitoring ping..its disconnecting for about half second and continue with 4g also...
Thanks in advance folk whoever answer my problem..
gflow
262
Likely your IP address is changing so the call will drop.
You can generally press hold and unhold and the call will come back up.
puneet936
14
but how i can handle that ? because we dont know when internet goes down right ?
gflow
262
You won't you'll need to hang up and call back unless you can go with an ISP that can provide you with a failover solution on a single IP.
puneet936
14
So that meant we have to use vpn or tunnel to keep consistent ip and connection
