SOLVED No data available in memcached for FusionPBX
Husnain Taseer
15
Hello Users,
I'm using FusionPBX 4.4.3 on "CentOS Linux 7 (Core)" but facing some weird issues. I created a gateway in FusionPBX with SIP provider details but the gateway was not starting/registering. After doing some troubleshooting, I have found that there is no data available in uderlying memcache database:
# telnet localhost 11211
Trying ::1...
telnet: connect to address ::1: Connection refused
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
stats items
END
There is no gateway config available in the memcached, however I can see Gateway is created on the UI. Also I have noticed that when I issue "Flush cache" Command from Advanced >> SIP Profiles >> Flush Cache no command receives on the memecahed as can be seen from "stats" command:
Trying ::1...
Trying 127.0.0.1...
stats
STAT pid 2929
STAT uptime 67
STAT time 1546027913
STAT version 1.4.15
STAT libevent 2.0.21-stable
STAT pointer_size 64
STAT rusage_user 0.002719
STAT rusage_system 0.006797
STAT curr_connections 6
STAT total_connections 7
STAT connection_structures 7
STAT reserved_fds 20
STAT cmd_get 0
STAT cmd_set 0
STAT cmd_flush 0
Further I connected to fs_cli and used memcahe flush command as below:
mydomain.com> memcache flush
+OK
and checked the stats again. This time stats was showing "STAT cmd_flush 1". Could you please guide me whats wrong with my configuration, why UI can't communicate with memcahe?
I also checked the system audit logs during that time but didn't find any errors in them. Any help regarding this matter will be highly appreciated.
markjcrane
448
162
New intsalls of FusionPBX don't use memcache anymore. Currently it will get installed but not used.
