SOLVED Not all Feature Codes work
imcontreras
My current Orig and Term provider: VoIP Innovation
My VPS Debian 9.4 x64
Fusion PBX v 4.5.3
Branch: master
Commit: 418eeb83e49f70ae7cfe8df67b849b671add7292
Multitenant system.
Phone GrandStream GXP1760W Version 1.0.0.94
What's working:
Ext registration successful
incoming calls working
outgoing calls working
internal calls between extensions working
Problem:
When dialing feature codes not all work
this feature code works fine:
*9664 - Test Music on Hold
*97 - Voicemail
This won't work, feature code fails:
*9196 - Echo Test
*9195 - Delay Echo
There's no log, call never reach PBX, I know the issue is on the phone but not sure where to start.
imcontreras
Don't Grandstream use dial strings?
It might be that it doesn't match the dial string and won't make that call.
Try to modify the XML file to this:
{if isset($grandstream_dial_plan) }
<P290>{$grandstream_dial_plan}</P290>
{else}
<P290>{literal}{<=1>xxxxxxxxxx|x+|*x+|*xx*x+}{/literal}</P290>
{/if}
not getting any improvement.
I'm new on fusion PBX and provisioning is really different from FreePBX (where I started)
will keep playing. Thanks
imcontreras
Thanks to everyone, just to mention this got resolved if anyone faces a similar situation try this solution:
deactivate the phone features codes in the following menu:
Account--> Feature codes.
Reactions: JamesBorne
