i'm try to debug my outbound call issue. On the log, i have saw call direction set as internal. Wich configuration i should check to make sure my outboud calls are set as outbound.
2024-03-25 18:23:18.921582 97.30% [DEBUG] sofia.c:7906 (sofia/internal/7000@pbx.surfyftu.com) State Change CS_NEW -> CS_INIT
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:600 (sofia/internal/7000@pbx.surfyftu.com) State NEW
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/7000@pbx.surfyftu.com) Running State Change CS_INIT (Cur 1 Tot 11)
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:624 (sofia/internal/7000@pbx.surfyftu.com) State INIT
2024-03-25 18:23:18.921582 97.30% [DEBUG] mod_sofia.c:97 sofia/internal/7000@pbx.surfyftu.com SOFIA INIT
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:40 sofia/internal/7000@pbx.surfyftu.com Standard INIT
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:48 (sofia/internal/7000@pbx.surfyftu.com) State Change CS_INIT -> CS_ROUTING
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:624 (sofia/internal/7000@pbx.surfyftu.com) State INIT going to sleep
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/7000@pbx.surfyftu.com) Running State Change CS_ROUTING (Cur 1 Tot 11)
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_channel.c:2399 (sofia/internal/7000@pbx.surfyftu.com) Callstate Change DOWN -> RINGING
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:640 (sofia/internal/7000@pbx.surfyftu.com) State ROUTING
2024-03-25 18:23:18.921582 97.30% [DEBUG] mod_sofia.c:158 sofia/internal/7000@pbx.surfyftu.com SOFIA ROUTING
2024-03-25 18:23:18.921582 97.30% [DEBUG] switch_core_state_machine.c:230 sofia/internal/7000@pbx.surfyftu.com Standard ROUTING
2024-03-25 18:23:18.921582 97.30% [INFO] mod_dialplan_xml.c:639 Processing 7000 <7000>->15146004436 in context public
2024-03-25 18:23:18.941568 97.30% [NOTICE] switch_cpp.cpp:1466 [xml_handler] multiple key:dialplan
ublic
Dialplan: sofia/internal/7000@pbx.surfyftu.com parsing [public->caller-details] continue=true
Dialplan: sofia/internal/7000@pbx.surfyftu.com Regex (PASS) [caller-details] () =~ // break=never
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action export(call_direction=inbound) INLINE
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com export(call_direction=inbound)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_channel.c:1334 EXPORT (export_vars) [call_direction]=[inbound]
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action set(caller_destination=${sip_to_user}) INLINE
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com set(caller_destination=15146004436)
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_dptools.c:1671 SET sofia/internal/7000@pbx.surfyftu.com [caller_destination]=[15146004436]
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com set(caller_id_name=7000)
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_dptools.c:1671 SET sofia/internal/7000@pbx.surfyftu.com [caller_id_name]=[7000]
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/internal/7000@pbx.surfyftu.com parsing [public->12264006234] continue=false
Dialplan: sofia/internal/7000@pbx.surfyftu.com Regex (FAIL) [12264006234] destination_number(15146004436) =~ /^(12264006234)$/ break=on-false
Dialplan: sofia/internal/7000@pbx.surfyftu.com parsing [public->15145321045] continue=false
Dialplan: sofia/internal/7000@pbx.surfyftu.com Regex (FAIL) [15145321045] destination_number(15146004436) =~ /^(15145321045)$/ break=on-false
Dialplan: sofia/internal/7000@pbx.surfyftu.com parsing [public->18193077286] continue=false
Dialplan: sofia/internal/7000@pbx.surfyftu.com Regex (FAIL) [18193077286] destination_number(15146004436) =~ /^(18193077286)$/ break=on-false
Dialplan: sofia/internal/7000@pbx.surfyftu.com parsing [public->not-found] continue=false
Dialplan: sofia/internal/7000@pbx.surfyftu.com Regex (PASS) [not-found] () =~ // break=on-false
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action set(call_direction=inbound) INLINE
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com set(call_direction=inbound)
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_dptools.c:1671 SET sofia/internal/7000@pbx.surfyftu.com [call_direction]=[inbound]
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action log(WARNING [inbound routes] 404 not found ${sip_network_ip} destination_number ${destination_number} sip_to_user ${sip_to_user} sip_req_user ${sip_req_user})
Dialplan: sofia/internal/7000@pbx.surfyftu.com Action respond(404 Not Found)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:281 (sofia/internal/7000@pbx.surfyftu.com) State Change CS_ROUTING -> CS_EXECUTE
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:640 (sofia/internal/7000@pbx.surfyftu.com) State ROUTING going to sleep
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/7000@pbx.surfyftu.com) Running State Change CS_EXECUTE (Cur 1 Tot 11)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:647 (sofia/internal/7000@pbx.surfyftu.com) State EXECUTE
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_sofia.c:213 sofia/internal/7000@pbx.surfyftu.com SOFIA EXECUTE
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:323 sofia/internal/7000@pbx.surfyftu.com Standard EXECUTE
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com set(caller_id_number=7000)
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_dptools.c:1671 SET sofia/internal/7000@pbx.surfyftu.com [caller_id_number]=[7000]
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com log(WARNING [inbound routes] 404 not found 94.121.43.102 destination_number 15146004436 sip_to_user 15146004436 sip_req_user 15146004436)
2024-03-25 18:23:18.941568 97.30% [WARNING] mod_dptools.c:1865 [inbound routes] 404 not found 94.121.43.102 destination_number 15146004436 sip_to_user 15146004436 sip_req_user 15146004436
EXECUTE [depth=0] sofia/internal/7000@pbx.surfyftu.com respond(404 Not Found)
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_sofia.c:2350 Responding with 404 [Not Found]
2024-03-25 18:23:18.941568 97.30% [NOTICE] mod_sofia.c:2416 Hangup sofia/internal/7000@pbx.surfyftu.com [CS_EXECUTE] [UNALLOCATED_NUMBER]
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_session.c:2979 sofia/internal/7000@pbx.surfyftu.com skip receive message [APPLICATION_EXEC_COMPLETE] (channel is hungup already)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:647 (sofia/internal/7000@pbx.surfyftu.com) State EXECUTE going to sleep
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/7000@pbx.surfyftu.com) Running State Change CS_HANGUP (Cur 1 Tot 11)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:844 (sofia/internal/7000@pbx.surfyftu.com) Callstate Change RINGING -> HANGUP
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:846 (sofia/internal/7000@pbx.surfyftu.com) State HANGUP
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_sofia.c:469 Channel sofia/internal/7000@pbx.surfyftu.com hanging up, cause: UNALLOCATED_NUMBER
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_sofia.c:614 Responding to INVITE with: 404
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:59 sofia/internal/7000@pbx.surfyftu.com Standard HANGUP, cause: UNALLOCATED_NUMBER
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:846 (sofia/internal/7000@pbx.surfyftu.com) State HANGUP going to sleep
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:616 (sofia/internal/7000@pbx.surfyftu.com) State Change CS_HANGUP -> CS_REPORTING
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/7000@pbx.surfyftu.com) Running State Change CS_REPORTING (Cur 1 Tot 11)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:932 (sofia/internal/7000@pbx.surfyftu.com) State REPORTING
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:168 sofia/internal/7000@pbx.surfyftu.com Standard REPORTING, cause: UNALLOCATED_NUMBER
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:932 (sofia/internal/7000@pbx.surfyftu.com) State REPORTING going to sleep
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:607 (sofia/internal/7000@pbx.surfyftu.com) State Change CS_REPORTING -> CS_DESTROY
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_session.c:1744 Session 11 (sofia/internal/7000@pbx.surfyftu.com) Locked, Waiting on external entities
2024-03-25 18:23:18.941568 97.30% [NOTICE] switch_core_session.c:1762 Session 11 (sofia/internal/7000@pbx.surfyftu.com) Ended
2024-03-25 18:23:18.941568 97.30% [NOTICE] switch_core_session.c:1766 Close Channel sofia/internal/7000@pbx.surfyftu.com [CS_DESTROY]
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:735 (sofia/internal/7000@pbx.surfyftu.com) Running State Change CS_DESTROY (Cur 0 Tot 11)
2024-03-25 18:23:18.941568 97.30% [DEBUG] switch_core_state_machine.c:745 (sofia/internal/7000@pbx.surfyftu.com) State DESTROY
2024-03-25 18:23:18.941568 97.30% [DEBUG] mod_sofia.c:380 sofia/internal/7000@pbx.surfyftu.com SOFIA DESTROY
2024-03-25 18:23:19.041579 97.30% [DEBUG] switch_core_state_machine.c:175 sofia/internal/7000@pbx.surfyftu.com Standard DESTROY
2024-03-25 18:23:19.041579 97.30% [DEBUG] switch_core_state_machine.c:745 (sofia/internal/7000@pbx.surfyftu.com) State DESTROY going to sleep
