Outbound Route Configuration Help
dmmincrjr
I'm having a couple issues configuring an Outbound Route and was hoping someone might be able to share a working configuration for the follow routes.
1. VOIP.ms International Route - I'm trying to make an outgoing call to the UK using VOIP.ms. The call fails as unavailable and when I look at the sip logs I'm getting a 403 Forbidden message from VOIP.ms. In a google ai search it is suggesting something maybe with the caller id. I have tried different caller id's and I even have a uk phone number from voip.ms that I've used but still getting the error. When I make a call to a US number on VOIP.ms it works fine. I do have the restriction removed for making international calls and have allowed the UK as a destination. I have an IncrediblePBX system running and am able to make the call out of that without issue so believe everything is configured correctly on VOIP.ms.
2. Anveo Retail Route - I have been trying to configure an outbound route using Anveo Retail but the calls always fail. I get a busy message in the call history and 486 Busy Here in the sip trace. I'm able to make incoming calls to the Anveo number but cannot make outgoing calls. Again a google ai search is saying probably something with the caller id as the caller id is going out as +1xxxxxxxxxx. Again I'm hoping someone has a working configuration that can point me to what I need to do to correct. I'm also able to make an outgoing call with my IncrediblePBX system.
One last question I have is regarding modifying an Outbound Route. When you create a route there is a place to put the Gateway and then Alternate Gateways. Once the route is created though I do not see a place to change the Gateway if you want to modify the primary gateway on the route. Do you need to create a new route with the gateway you want to use as the primary?
