Phrases not working
It does not seem that the Phrases function is working. When initiating a Phrase through the IVR there is no playback. This is a simple, single wav file, test of the Phrases functionality and to leverage it for more complex tasks. As both the Phrase and the system recording the phrase call is available in the IVR, I did test both options and am able to play the wav file directly.
Here is a snippet from FreeSwitch when the Phrase is called by the IVR
2019-03-07 18:00:23.805059 [DEBUG] switch_ivr_play_say.c:70 No language specified - Using [en]
2019-03-07 18:00:23.825055 [ERR] switch_ivr_play_say.c:145 Can't find macro 393fa6b6-b2d6-4849-844e-348307c0b10d.
My testbed happens to be on a multi-tenant server so I'm not sure where the problems lies. Obviously, it can't find the phrase macro. I'm not sure if its a language issue, multi-tenant issue, or a general app/feature issue.
I have played with the language configuration of the phrase; trying en, en-us, and en-us callie (matching the language of the IVR). If I try nothing, FusionPBX asks for one and prevents the change. I've not had a need to utilize any of the language functionality before and don't know if this is creating the issue.
It is a multi-tenant system, so I would expect to see the domain uuid in addition to the macro uuid. It's obviously not there, but that may not have any bearing on the database call to find the recording. There is no place in the interface to select the domain or global option, but I did check to see of the phrases where domain specific... they are.
Lastly, FusionPBX is an awesome tool with and incredible amount of functionality. My experience is that some of the functions are not fully implemented or need some tweeking out of the box. Phrases my be one of those features.
Any guidance would appreciated.
Same issue here - and agree with the other comments :)
The individual sound files work ok, but when not when in a phrase.
I have worked through the docs for this multi tenant install and get the same silence and output as the OP above
Any guidance would be appreciated
In case anyone else is looking for help, I ran into this issue yesterday as well where my phrases were not working. I looked back through the commit history on the docs at GitHub. It looks like the fix in the docs mentioned in a previous post was to a screenshot that used to show en-us as the language setting in a phrase. This was changed to show using en as the setting.
After I changed my phrase setting to en, I had to go to Status >> Sip Status and hit the Flush Cache button for it to start working.
Thanks, that's exactly what it was, I couldn't remember. I was only debugging for someone else on here.
Yeah I had the same problem, except in my opinion the whole language support in fusionpbx is broken. "en" whilst being a language is not sufficient to specify exactly what sound files are played. As you probably know, "en" then refers FreeSwitch to the language xml files in /etc/freeswitch or those built dynamically in /var/cache\memcache, which then in turn refers to the hard-coded en/us/callie path.
The phrase language should actually refer directly to the triple: language, dialect, voice, as should the XML files. This would allow full multi-lingual and even multi-voice support: en-us-callie, en-us-mark, en-ca-june, en-au-bruce, en-gb-john, etc and also allow phrases to be defined for multiple languages in the same domain, rather than relying on a fixed default_language, for multi-lingual ivrs for example. In your dialplan you can define the 'language' variable as en-ca-june for example and freeswitch will play the files from that language (if installed), provided there is a language xml file with a matching name defined internally.
No language specified - Using [en] refers to FreeSwitch not finding the language variable and falling back on the default_language variable set globally.
It just so happens I've fixed this in my fork (racitup), works quite well, and no more Can't find macro 393fa6b6-b2d6-4849-844e-348307c0b10d which was actually a bug in the sql lookup: it was looking up both the phrase UUID AND the language to build the cached phrase xml. So if the db phrase language string didn't exactly match the default_language, you got the error because the cached file had no content.
I'm hoping my PR's will be integrated for the long-awaited next release.
