Pinless voicemail??
WhizzyInternet
13
Hi! I am trying to find is there way to set pinless access to voicemail if dialing from own extension. Also what is procedure to change Voicemail access number from *97 to 171
Amit Iyer
56
11
To change the Voicemail access number, go to Advance -> Default Settings.
under provisioning you will have a voicemail extension. You can change it from there.
Regarding the Pinless voicemail, i have no idea about it.
WhizzyInternet
13
I know 2600hz have managed it on their kazoo. on monster-ui there is option to enable pinless voicemail. kazoo is built on top of freeswitch too.
WhizzyInternet
13
Changing voicemail access number in provision section changes default voicemail number for provision templates and not for dialplan.
