Problem with blind transfer
Hi all,
I've got multi tenant FusionPBX4.4 installed with default settings and trying to make a blind transfer/attended transfer on on the client but something goes wrong.
I've enabled "bind_digit_action" option in the dialplan. The server is receiving DTMF (i can see that in the logs). During the conversation if client B press *1 or *4 it hears the moh on its bleg while the caller on the aleg hear the tone so the caller can actually transfer the call.
2018-11-14 21:53:48.565430 [NOTICE] switch_ivr_originate.c:3740 Channel [sofia/external/4444444444@X.X.X.X] has been answered
2018-11-14 21:53:48.565430 [DEBUG] switch_channel.c:3781 (sofia/external/4444444444@X.X.X.X) Callstate Change EARLY -> ACTIVE
2018-11-14 21:53:48.565430 [DEBUG] sofia.c:7291 Channel sofia/external/4444444444@X.X.X.X entering state [completed][200]
2018-11-14 21:53:48.565430 [DEBUG] switch_ivr_originate.c:3798 Originate Resulted in Success: [sofia/internal/18@Z.Z.Z.Z:5060]
2018-11-14 21:53:48.565430 [DEBUG] switch_ivr_bridge.c:1782 (sofia/internal/18@Z.Z.Z.Z:5060) State Change CS_CONSUME_MEDIA -> CS_EXCHANGE_MEDIA
2018-11-14 21:53:48.565430 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/18@Z.Z.Z.Z:5060) Running State Change CS_EXCHANGE_MEDIA (Cur 2 Tot 8601)
2018-11-14 21:53:48.565430 [DEBUG] switch_core_state_machine.c:653 (sofia/internal/18@Z.Z.Z.Z:5060) State EXCHANGE_MEDIA
2018-11-14 21:53:48.565430 [DEBUG] mod_sofia.c:645 SOFIA EXCHANGE_MEDIA
2018-11-14 21:53:48.585408 [DEBUG] sofia.c:7291 Channel sofia/external/4444444444@X.X.X.X entering state [ready][200]
2018-11-14 21:53:48.645427 [DEBUG] switch_rtp.c:7550 Correct audio ip/port confirmed.
2018-11-14 21:53:49.225402 [DEBUG] switch_rtp.c:7550 Correct audio ip/port confirmed.
2018-11-14 21:53:52.345430 [DEBUG] switch_rtp.c:7789 RTP RECV DTMF *:960
2018-11-14 21:53:52.345430 [INFO] switch_channel.c:515 RECV DTMF *:960
2018-11-14 21:53:52.985418 [DEBUG] switch_rtp.c:7789 RTP RECV DTMF 1:1440
2018-11-14 21:53:52.985418 [INFO] switch_channel.c:515 RECV DTMF 1:1440
2018-11-14 21:53:52.985418 [DEBUG] mod_dptools.c:188 sofia/external/4444444444@X.X.X.X Digit match binding [exec:execute_extension][dx XML client1.sip.company.eu]
2018-11-14 21:53:53.325430 [DEBUG] switch_ivr.c:625 sofia/internal/18@Z.Z.Z.Z:5060 Command Execute playback(local_stream://default)
EXECUTE sofia/internal/18@Z.Z.Z.Z:5060 playback(local_stream://default)
2018-11-14 21:53:53.325430 [DEBUG] mod_local_stream.c:901 Opening Stream [default/8000] 8000hz
2018-11-14 21:53:53.325430 [DEBUG] switch_ivr_play_say.c:1493 Codec Activated L16@8000hz 1 channels 20ms
2018-11-14 21:53:53.325430 [DEBUG] switch_ivr.c:625 sofia/external/4444444444@X.X.X.X Command Execute execute_extension(dx XML client1.sip.company.eu)
EXECUTE sofia/external/4444444444@X.X.X.X execute_extension(dx XML client1.sip.company.eu)
Would it be possible to change that behavior to allow transfers to the client on its bleg?
On the server where blind transfer works i've got following correspondent log:
2018-11-14 22:04:18.965223 [DEBUG] switch_rtp.c:7534 RTP RECV DTMF *:1120
2018-11-14 22:04:18.965223 [INFO] switch_channel.c:515 RECV DTMF *:1120
2018-11-14 22:04:19.545214 [DEBUG] switch_rtp.c:7534 RTP RECV DTMF 1:1120
2018-11-14 22:04:19.545214 [INFO] switch_channel.c:515 RECV DTMF 1:1120
2018-11-14 22:04:19.545214 [DEBUG] mod_dptools.c:188 sofia/internal/10@Z.Z.Z.Z:5060 Digit match binding [exec:execute_extension][dx XML client2.sip.company.eu]
2018-11-14 22:04:19.865198 [DEBUG] switch_ivr.c:623 sofia/external/4444444444@X.X.X.X Command Execute playback(local_stream://default)
2018-11-14 22:04:19.865198 [DEBUG] switch_ivr.c:623 sofia/internal/10@Z.Z.Z.Z:5060 Command Execute execute_extension(dx XML client2.sip.company.eu)
EXECUTE sofia/external/4444444444@X.X.X.X playback(local_stream://default)
EXECUTE sofia/internal/10@Z.Z.Z.Z:5060 execute_extension(dx XML client2.sip.company.eu)
Hi, ehrny, how are you?
Do you have any updates on this? I have the same problem. After an extension receive an incoming call, they attempt to do a Attended Transfer to a second extension, but after pressing the *4, the extension hear the MOH and the caller receive the BIP to dial the extension and be transferred. It looks like A-Leg and B-Leg are switched. We are using version 4.4.1.
Hi Rafael,
i was able to sort it out by adding ,${bind_target} at the end of data fields .
go to Dialplan->Dialplan Manager->blind_digit_action
then change data fields accordingly:
local,*1,exec:execute_extension,dx XML ${context},${bind_target}
local,*2,exec:execute_extension,dx XML ${context},${bind_target}
local,*3,exec:execute_extension,dx XML ${context},${bind_target}
local,*4,exec:execute_extension,dx XML ${context},${bind_target}
BR
Current installation already has this field. This not works for me.
With your adjustment, seems Attended Transfer it will not work for you, right? You are using *4 with "dx" and we need as "att_xfer".
I'm not sure, but I'm think it's some bug with Freeswitch 1.8.5 that switched the legs. I opened a ticket in Freeswitch.
Does anyone has some tips?
Any updates on this, or a link to the Freeswitch ticket maybe? Having the same issue here.
Also, looks like ehrny just copy-paste the one line 4 times and changed the *# but forgot the rest ;)
I've tried playing around with the different settings for DTMF and Event attributes but didn't really get anywhere useful.
If I add another ,${bind_target} to the end it does work, but both sides get the Dial Tone.
If B-leg enters an extension is works, but if A-leg enters anything it drops the call.
I have found the solution but don't know how to make it work for all the options *1 *2 *3 and *4. At the moment only the one that is configured to the BLEG will work as expected. Maybe some guru will help out more. Here is a screenshot of the modified extension.
