Provisioning multiple Device Profiles With unique Multicast addresses
rkbsimpsipper
I have a single k-12 school district deployment. I have several device profiles that separate the grade groups. I am wanting to edit a provisioning file to contain each grade groups multicast page group. But I want this config to essentially be tied to the device profiles associated with each grade group so no paging happens inbetween a High School and the Elementary. I can edit the default provisioning config, but this ends up being a global setting. I have not figured out the method to add the multicast address within the device profiles "settings" itself, successfully. Can anyone please guide me into either path, webui or editing a cfg whatever. I am using fanvil phones if that helps.
I greatly appreciate any help received
The fix below. I was over thinking it. Maybe this can help someone.
Simply copy the device template, give www-data folder permissions, edit mac.cfg file to your liking, then assign device in webui correct template.
EX:
cd /var/www/fusionpbx/resources/templates/provision/fanvil
sudo cp -r x7a x7a-es
sudo chown -R www-data x7a-es
cd x7a-es
sudo gedit '{mac}.cfg'
Edit that thing
provision that thing
KB
