Provisioning outbound proxy parameter
kt351b
33
Hello! Is it normal behavior that when I change at Advanced -> Default Settings -> Provision -> outbound_proxy_primary, outbound_proxy_secondary, and press Reload, the outbound_proxy parameter at device provision file (Accounts -> Devices -> Files -> mac.cfg) doesn't change ?
But after I delete the device and create it again, the outbound_proxy parameter is changed.
I flushed cache, reloaded XML, and rebooted server also, but no luck. Still have to delete and to add the device again to get the proper config file.
My FusionPBX version is 4.5.19
I believe those default settings are used to pre-populate the form when you add a new device or new device line, they will not have any effect on device records that have already been created.
Reactions: kt351b
kt351b
33
Thanks. Ok, I see, so when I need to reassign the outbound proxy I should export all the devices and then import them back.
197
Export/import is messy. The bulk account settings app I linked to allows you to skip all of that and avoid conflicts.
Select the type of change you want
Select the field you want to bulk change
Enter new data in box, select which devices etc to update and click "submit"
