Provisioning
mark.milton
22
Hoping someone can help. My desk phone has suddenly stopped registering. The phone tries a few times then fails. I looked at sngrep that shows the phone trying to connect and never shows any error or at least that I can see.
bdmonsey
146
are you registering with Auto provisioning or manually?
did you check if your ip got blocked with fail2ban?
bdmonsey
146
Would really need more info to really know whats behind it, I would try first to change to TCP, and minimize the expiration. other than that I would probably need to see.
do you wanna try auto provision?
mark.milton
22
Switching to TCP also failed.
Can try auto provisioning. Do I add the server URL with HTTP or HTTPS? Also the user name as password is that the extension number and password or the user connected to the extension?
