Recommendation for WiFi Phone
Andyd358
245
UK
Hi
Anyone recommed a Wifi capable Voip hand set. Not Dect. The reason for this is we have a few Care homes who sufer from bad reception from the yealink Base sations even with repeaters placed around the building. We do however have very good WiFi coverage over the whole of the building.
Was thinking this:
Any alternatives?
We have used the WP810 quite successfully. For seamless roaming I think you need a good managed wifi network.
Andyd358
245
UK
Morning Adrian, Thanks for the recomedation. Thats the one we have been looking at. Yeah the WiFi coverage is pretty good so should not be a problem.
Funny thing though when I googled it I found a thread on here from 2 years ago where I kind of asked the same question (I forgot I had) and you recomended the same phone then :)
smeyer
24
I have also had great success buying super cheap cell phones from amazon and using those.
