Recording Lenny
ChrisLab
33
Hi All.
I followed Adrian's instructions here to get Lenny up and running, and it works like a charm.
My question is, how would one record the incoming call when the call hits Lenny?
My inbound rule looks like this:
condition > destination_number > ^(myDIDnumber)$
action > set > effective_caller_id_number=incoming_caller_id_number${caller_id_number}
action > lua > /etc/freeswitch/scripts/lenny.lua
I tried putting a action > record in there, but I'm obviously missing something somewhere.
Thanks!
You can use any of the following depending on your requirements:
mod_dptools record https://developer.signalwire.com/freeswitch/FreeSWITCH-Explained/Modules/mod-dptools/6587041
mod_dptools record_session https://developer.signalwire.com/freeswitch/FreeSWITCH-Explained/Modules/mod-dptools/6587110/
mod_commands uuid_record https://developer.signalwire.com/fr...ined/Modules/mod_commands_1966741#uuid_record
Whatever method you choose, pay attention to the various associated channel variables, that help you to configure the recording.
Hi all,
I got it to work with mod_dptools record_session.
It unfortunately doesn't show up under call detail records, or call recordings, but the .wav file is there.
Thanks for the help!
What are your plans for identifying inbound calls to be sent to Lenny? Do you have any spam score data?
Are you planning on turning Lenny into a destination so you can push calls to it as part of the call block treatment?
Hi. I currently don't have any advanced plans for identifying spam. At the moment I have a couple of DID's thats setup manually to go to the lenny script.
