Reload Freeswitch without dropping connections
Robert Birch
111
I want to make a change to the /etc/freeswitch/autoload_configs/logfile.conf.xml file.
Is there a way to make freeswitch reload the config file without dropping registrations, calls, etc?
Thanks,
Bob
At the command line:
fs_cli -x "reload <mod_name>"
Beware some modules will not reload. It may be worth trying a "reloadxml" first.
Robert Birch
111
So that would be
fs_cli -x "reload logfile"?
If I did the reloadxml will that mess up the pre-process variables from the other XML files?
Thanks.
PS: forgot to say fs_cli -x "reloadxml" will not mess up the pre-process variables from the other XML files.
Robert Birch
111
Ok. I found out I could enter fs_cli and do a fsctl loglevel <level numer>
I used 6 to just drop the debug messages.
This doesn't require a reload of any kind.
I checked the log file and it is working as I expect.
Thanks for all the help and pointing me in the correct direction.
