Restoring a backup - Permission denied issue
Andrew Byrd
309
I have run backup on one server and then restore to a different server and when I get almost to the restore complete I get this message:
nice: '/etc/cron.daily/./fusionpbx-backup.sh': Permission denied
Any ideas on this?
Debian 10
FPBX 4.11.5
Much more likely the script hasn't got execute permissions, it wants to run it but needs a chmod +x
Andrew Byrd
309
I seem to have fixed the chmod issue and have another issue. When I backup I get this message
root@abnetworks:~# /etc/cron.daily/fusionpbx-backup.sh
Server Backup
find: '/var/log/postgresql/postgresql-9.4-main*': No such file or directory
find: '/usr/local/freeswitch/log/freeswitch.log.*': No such file or directory
pg_dump: error: connection to database "fusionpbx" failed: FATAL: Peer authentication failed for user "fusionpbx"
Backup Complete
Can you point me in the right direction on this error?
Where have you got this backup script? /usr/localfreeswitch comes from the dinosaur days of building from source?
Andrew Byrd
309
I got the script right off of fusionpbx docs
I changed the ssh server and the password to xxxxxx's but all the rest is what I used
#!/bin/sh
now=$(date +%Y-%m-%d)
ssh_server=xx.xx.xx.xx
database_host=127.0.0.1
database_port=5432
export PGPASSWORD="xxxxxxxxxxxxxxxxx"
#run the remote backup
ssh -p 22 root@$ssh_server "nice -n -20 /etc/cron.daily/fusionpbx-backup"
#delete freeswitch logs older 7 days
find /var/log/freeswitch/freeswitch.log.* -mtime +7 -exec rm {} \;
#synchronize the backup directory
#rsync -avz -e 'ssh -p 22' root@$ssh_server:/var/backups/fusionpbx /var/backups
rsync -avz -e 'ssh -p 22' root@$ssh_server:/var/backups/fusionpbx/postgresql /var/backups/fusionpbx
rsync -avz -e 'ssh -p 22' root@$ssh_server:/var/www/fusionpbx /var/www
rsync -avz -e 'ssh -p 22' root@$ssh_server:/etc/fusionpbx /etc
find /var/backups/fusionpbx/postgresql -mtime +2 -exec rm {} \;
rsync -avz -e 'ssh -p 22' root@$ssh_server:/etc/freeswitch/ /etc
rsync -avz -e 'ssh -p 22' root@$ssh_server:/var/lib/freeswitch/storage /var/lib/freeswitch
rsync -avz -e 'ssh -p 22' root@$ssh_server:/var/lib/freeswitch/recordings /var/lib/freeswitch
rsync -avz -e 'ssh -p 22' root@$ssh_server:/usr/share/freeswitch/scripts /usr/share/freeswitch
rsync -avz -e 'ssh -p 22' root@$ssh_server:/usr/share/freeswitch/sounds /usr/share/freeswitch
echo "Restoring the Backup"
#extract the backup from the tgz file
tar -xvpzf /var/backups/fusionpbx/backup_$now.tgz -C /
#remove the old database
psql --host=$database_host --port=$database_port --username=fusionpbx -c 'drop schema public cascade;'
psql --host=$database_host --port=$database_port --username=fusionpbx -c 'create schema public;'
#restore the database
pg_restore -v -Fc --host=$database_host --port=$database_port --dbname=fusionpbx --username=fusionpbx /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql
#restart freeswitch
service freeswitch restart
echo "Restore Complete";
Andrew Byrd
309
What I do is spin up a new server with Debian 10, Fusionpbx, and ensure Postgresql are the same version (12.1)
Then I run the back up script o the production server. Then I ssh to the backupserver and run the restore command. It now shows restore successful, but when I login there is no data there - just a blank copy of Fusion.
Sorry, I have never used this method to backup, I guess I would just look at the backup script and reverse the actions. I didn't actually realize there is no restore!
