Hi
i've fusionpbx and its connected to provider as IP Authentication
I have another PBX (FREEPBX For example) and will make a trunk between freepbx and fusionpbx
All the DIDs are define in Fusionpbx and i want to route the Calls from Fusionpbx to Freepbx base on the calls coming on DIDs
So on FREEPBX side i should be able to see real Caller ID and the DID
Appreciate if you guys can help
