Same outbound caller ID for all domains/extensions instead of what's set
5280pbx
68
Howdy. Any common reason why extensions on all domains are showing the same caller ID and not what is set at ext level? It's not carrier overriding, I know this. Thx!
197
My first guess would be the carrier or your gateway settings if all domains use the same gateway.
The only other way is if there is a static caller id value in a global dial plan.
The most common source would be in a global outbound route, or possibly in the "global-variables" dial plan.
