Edit: remove walls of text to make it more readable.
Is Kamailio ideal to circumvent CG-NAT on multiple on-premise Fusion installs? Goal is to provide connectivity to just a handful of roaming users per location. So most endpoints would be local to their respective Fusion box, Kamailio would only serve roaming users (since they can't directly connect to Fusion due to aforementioned CG-NAT).
If there are other methods I would appreciate the input. Many thanks.
