SOLVED SIP Gateway without authentication credentials
ewdpb
151
19
Hi all,
I have a project where I need my FusionPBX to use an Audiocodes SBC as a gateway for all calls (in/out).
The question came when setting up the SIP Trunk against the Audiocodes. As far as a I know in FusionPBX and freeswitch world a SIP Trunk would be a Gateway. In FusionPBX, the Username/Password in a gateway definition is mandatory. How can I make it not to be so? Audiocodes does not require or provide credentials. We checked with an Avaya and a Cisco switch and neither of them require authentication, they are authenticated based on IP (similar to Asterisk peers). How can get this set up here?
In Sofia config files, I found the auth-calls parameter but it does not seem to actually fit the need.
Any help will be welcome.
Thanks!
ewdpb
151
19
ahh! it can't get easier than that! thanks @DigitalDaz, I will give it a go. I have a follow up question but I will post it in a separate thread.
