Skyetel SMS
pbx123
17
I'm trying to get SMS working with FusionPBX (current master). I can curl to Skyetel and send a message, but FusionPBX gives me two errors: Can't find registered user and Not sending message to ourselves!. I setup the SID and Secret in defaults. Does it need an api_url added as well?. Skyetel supports FusionPBX, but it's not in the list of carriers, so I added it into defaults. Has anyone got FusionPBX SMS to work with Skyetel?
I have SMS with Skyetel working but keep in mind future updates can and will likely break current functions.
SMS is one of the "to-dos" before the next release. Some of the changes needed to make other carriers work will quite likely change from current settings.
In Skyetel portal SMS settings:
Forward= Callback URL
URL= https://pbx.mydomain.com/app/messages/index.php?key=MyLongFusionpbxMessageKey
Method=POST
The "Message Key" comes from the "User" settings of the user with access to the telephone number you want SMS to work with.
In Fusion Default Settings:
Thanks so much. I set up those parameters, but still getting "Can't find registered user" xxx@xxxx.xxxxx (xxx=phone number of sms recipient) in the logs. Do you by chance have a copy of the apps/sms/carrier_sms_hooks.php file you use for Skyetel? Skyetel isn’t listed in the carriers. I tried twillio and the others, but didn’t fix the issue. I can receive sms on the phone, just can’t send.
The above info works with app/messages as found in Master branch. Look closely at the URL in Skyetel info above.
I don't have the other SMS app installed. That is a whole different animal.
Thanks, appreciate the help. The messages app logs the received sms's, just can't send via the phone or messages app. I'll keep searching and post if I get the solution.
Did you ever find a solution for sending SMS with the softphone app? I am able to receive messages but I can not send any messages. I can, however, send messages directly from the messages app in Fusion.
