hi
fspbx 2.0.1
i had inbound/outbound working fine with flowroute trunk but then decided to change registration port from 5061 to 5071.
Now inbound works but outbound says connection refused (MicroSIP soft phone). I'm using ip auth for outbound so nothing should really change as far a outbound route config in fspbx. any pointers as to what i should look at?
What's strange is that a hardware yealink makes the outbound call fine (same domain and trunk). They're both register fine and i can make inbound calls to both extensions.
SOLUTION:
If you do not use a proxy: Append the port to both the SIP Server and Domain fields in the format server: port and domain: port in MicroSIP. I've only had port in the SIP server field!
fspbx 2.0.1
SOLUTION:
