Hello!
I have setup an install on Deb 12 using a single NIC on a separate VLAN on our network with a dedicated router with a external static IP.
I have my gateway working, I have a registered phone but I cannot get any calls in no matter what settings I change. I have the following setup:
I have our main DID set to forward to my desk phone (Ext 202) and the action in the inbound routes shows:
action transfer 202 XML 10.12.1.250
If I change it to 202 XML PBX.TLD.COM the call goes to my voicemail, i can leave a message and my phone shows the voicemail which I can listen to but the phone never rings.
Am I missing something in the inbound routes or is there a setting I forget to turn on?
Thanks in advance!
- NIC has a 10.12.1.250 address and is connected to a router that has a static external IP
- I have a DNS record pointing to pbx.tld.com which resolves to the external IP
- I have disabled the internal SIP profile as there are no devices on that network
- The external SIP profile has the ports changed to 5060 and 5061 as Twilio doesn't use 5080/5081
- I created an extension and username for myself with an inbound route going to my extension
- ACLs are setup with Twilio's IPs and the router is allowing all ports from those IPs
- All phone traffic goes out through the internet to a separate network hosting FusionPBX
- phone is on 192.168.30.x and PBX is on 10.12.1.x
Thanks in advance!
