(Solved (Im an Idiot)) Problem with a restore.
Andyd358
243
UK
Fresh in stall of Fusion on Debian 9.
Ran a restore and it ended with:
pg_restore: error: could not open input file "/var/backups/fusionpbx/postgresql/fusionpbx$": No such file or directory
Restore Complete
So checked if the files where there:
root@pbx:~# cd /var/backups/fusionpbx/postgresql
root@pbx:/var/backups/fusionpbx/postgresql# ls
fusionpbx_pgsql_2021-04-20.sql fusionpbx_pgsql_2021-04-21.sql fusionpbx_pgsql_2021-04-22.sql
Even tried another fresh install and got the same issue. Any Ideas?
Andyd358
243
UK
Oh well looks like I had something wrong with the script I was using to restore i had the line
pg_restore -Fc --host=127.0.0.1 --dbname=fusionpbx --username=fusionpbx /var/backups/fusionpbx/postgresql/fusionpbx$
Searched through the forums again and found
pg_restore -Fc --host=127.0.0.1 --dbname=fusionpbx --username=fusionpbx /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql
Changed that line to that and it sorted the issue.
