freeswitch@vpsXXXXXX.ovh.net> sofia global siptrace on
+OK Global siptrace on
recv 1118 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.447849:
INVITE sip:gw+1d9c1c6c-14d9-45b5-a020-512905541a56@149.xxx.xxx.xxx:5060;transport=udp3 SIP/2.0
Via: SIP/2.0/UDP 188.xxx.xxx.xxx:5060;branch=z9hG4bK6cd3b867;rport
Max-Forwards: 70
From: "3xxxxxxxxxx" <sip:3xxxxxxxxxx@188.xxx.xxx.xxx>;tag=as35644109
To: <sip:gw+1d9c1c6c-14d9-45b5-a020-512905541a56@149.xxx.xxx.xxx:5060;transport=udp3>
Contact: <sip:3xxxxxxxxxx@188.xxx.xxx.xxx:5060>
Call-ID:
154e5165590d75707aae9f386b9dac14@188.xxx.xxx.xxx:5060
CSeq: 102 INVITE
User-Agent: MOR Softswitch
Date: Tue, 13 Feb 2018 14:56:20 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Remote-Party-ID: "3xxxxxxxxxx" <sip:3xxxxxxxxxx@188.xxx.xxx.xxx>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 314
v=0
o=root 1572885576 1572885576 IN IP4 188.xxx.xxx.xxx
s=Asterisk PBX 1.8.32.3
c=IN IP4 188.xxx.xxx.xxx
t=0 0
m=audio 12512 RTP/AVP 8 18 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
send 374 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.448329:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 188.xxx.xxx.xxx:5060;branch=z9hG4bK6cd3b867;rport=5060
Call-ID:
CSeq: 102 INVITE
User-Agent: FreeSWITCH
Content-Length: 0
2018-02-13 15:56:19.508364 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [7c07ccea-1f62-4e57-b94b-4e5d0b62a8a7]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_NEW (Cur 1 Tot 131)
2018-02-13 15:56:19.508364 [DEBUG] sofia.c:9873 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx receiving invite from 188.xxx.xxx.xxx:5060 version: 1.6.20 -37-987c9b9 64bit
2018-02-13 15:56:19.508364 [DEBUG] sofia.c:9989 IP 188.xxx.xxx.xxx Approved by acl "domains[]". Access Granted.
2018-02-13 15:56:19.508364 [DEBUG] sofia.c:7084 Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx entering state [received][100]
2018-02-13 15:56:19.508364 [DEBUG] sofia.c:7094 Remote SDP:
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[GSM:3:8000:20:13200:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:3061 Set Codec sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx PCMA/8000 20 ms 160 samples 64000 bits 1 channels
2018-02-13 15:56:19.508364 [DEBUG] switch_core_codec.c:111 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Original read codec set to PCMA:8
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
2018-02-13 15:56:19.508364 [DEBUG] switch_core_media.c:4767 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Set 2833 dtmf send payload to 101 recv payload to 101
2018-02-13 15:56:19.508364 [DEBUG] sofia.c:7507 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_NEW -> CS_INIT
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State NEW
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_INIT (Cur 1 Tot 131)
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State INIT
2018-02-13 15:56:19.508364 [DEBUG] mod_sofia.c:90 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA INIT
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:40 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard INIT
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_INIT -> CS_ROUTING
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State INIT going to sleep
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_ROUTING (Cur 1 Tot 131)
2018-02-13 15:56:19.508364 [DEBUG] switch_channel.c:2249 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Callstate Change DOWN -> RINGING
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING
2018-02-13 15:56:19.508364 [DEBUG] mod_sofia.c:143 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA ROUTING
2018-02-13 15:56:19.508364 [DEBUG] switch_core_state_machine.c:236 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard ROUTING
2018-02-13 15:56:19.508364 [INFO] mod_dialplan_xml.c:637 Processing 3xxxxxxxxxx <3xxxxxxxxxx>->1619 in context public
2018-02-13 15:56:19.608334 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fefd40def90 Connected.
2018-02-13 15:56:19.628335 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fefd40def90 released.
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [public->1319] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [1319] destination_number(1619) =~ /^(1319)$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [public->1619] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [1619] destination_number(1619) =~ /^(1619)$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(call_direction=inbound) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(call_direction=inbound)
2018-02-13 15:56:19.628335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_direction]=[inbound]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(domain_uuid=9f28c57f-5bb1-4b77-9540-170aaf3655aa) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(domain_uuid=9f28c57f-5bb1-4b77-9540-170aaf3655aa)
2018-02-13 15:56:19.628335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [domain_uuid]=[9f28c57f-5bb1-4b77-9540-170aaf3655aa]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(domain_name=pbx.xxxxxxxxxxxxxxxxxxx.com) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(domain_name=pbx.xxxxxxxxxxxxxxxxxxx.com)
2018-02-13 15:56:19.628335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [domain_name]=[pbx.xxxxxxxxxxxxxxxxxxx.com]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action transfer(100 XML pbx.xxxxxxxxxxxxxxxxxxx.com)
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_ROUTING -> CS_EXECUTE
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING going to sleep
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_EXECUTE (Cur 1 Tot 131)
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE
2018-02-13 15:56:19.628335 [DEBUG] mod_sofia.c:198 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA EXECUTE
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:328 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard EXECUTE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx transfer(100 XML pbx.xxxxxxxxxxxxxxxxxxx.com)
2018-02-13 15:56:19.628335 [DEBUG] switch_ivr.c:2165 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_EXECUTE -> CS_ROUTING
2018-02-13 15:56:19.628335 [NOTICE] switch_ivr.c:2172 Transfer sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx to XML[100@pbx.xxxxxxxxxxxxxxxxxxx.com]
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE going to sleep
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_ROUTING (Cur 1 Tot 131)
2018-02-13 15:56:19.628335 [DEBUG] mod_sofia.c:143 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA ROUTING
2018-02-13 15:56:19.628335 [DEBUG] switch_core_state_machine.c:236 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard ROUTING
2018-02-13 15:56:19.628335 [INFO] mod_dialplan_xml.c:637 Processing 3xxxxxxxxxx <3xxxxxxxxxx>->100 in context pbx.xxxxxxxxxxxxxxxxxxx.com
2018-02-13 15:56:19.628335 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fefd40def90 Connected.
2018-02-13 15:56:19.668338 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fefd40def90 released.
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->user_exists] continue=true
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(user_exists=true)
2018-02-13 15:56:19.668338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [user_exists]=[true]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [user_exists] ${user_exists}(true) =~ /^true$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(extension_uuid=${user_data ${destination_number}@${domain_name} var extension_uuid}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(extension_uuid=121c9bc6-d594-4fcc-b3cc-dcba7ca028df)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [extension_uuid]=[121c9bc6-d594-4fcc-b3cc-dcba7ca028df]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(hold_music=${user_data ${destination_number}@${domain_name} var hold_music}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(hold_music=local_stream://default)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [hold_music]=[local_stream://default]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_all_enabled=${user_data ${destination_number}@${domain_name} var forward_all_enabled}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_all_enabled=false)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_all_enabled]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_all_destination=${user_data ${destination_number}@${domain_name} var forward_all_destination}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_all_destination=)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_all_destination]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_busy_enabled=${user_data ${destination_number}@${domain_name} var forward_busy_enabled}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_busy_enabled=false)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_busy_enabled]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_busy_destination=${user_data ${destination_number}@${domain_name} var forward_busy_destination}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_busy_destination=)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_busy_destination]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_no_answer_enabled=${user_data ${destination_number}@${domain_name} var forward_no_answer_enabled}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_no_answer_enabled=false)
2018-02-13 15:56:19.688336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_no_answer_enabled]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_no_answer_destination=${user_data ${destination_number}@${domain_name} var forward_no_answer_destination}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_no_answer_destination=)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_no_answer_destination]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_user_not_registered_enabled=${user_data ${destination_number}@${domain_name} var forward_user_not_registered_enabled}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_user_not_registered_enabled=false)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_user_not_registered_enabled]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(forward_user_not_registered_destination=${user_data ${destination_number}@${domain_name} var forward_user_not_registered_destination}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(forward_user_not_registered_destination=)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_user_not_registered_destination]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(do_not_disturb=${user_data ${destination_number}@${domain_name} var do_not_disturb}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(do_not_disturb=false)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [do_not_disturb]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(call_timeout=${user_data ${destination_number}@${domain_name} var call_timeout}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(call_timeout=30)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_timeout]=[30]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(missed_call_app=${user_data ${destination_number}@${domain_name} var missed_call_app}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(missed_call_app=)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [missed_call_app]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(missed_call_data=${user_data ${destination_number}@${domain_name} var missed_call_data}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(missed_call_data=)
2018-02-13 15:56:19.708335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [missed_call_data]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(toll_allow=${user_data ${destination_number}@${domain_name} var toll_allow}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(toll_allow=)
2018-02-13 15:56:19.728335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [toll_allow]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(call_screen_enabled=${user_data ${destination_number}@${domain_name} var call_screen_enabled}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(call_screen_enabled=false)
2018-02-13 15:56:19.728335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_screen_enabled]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->call-direction] continue=true
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [call-direction] ${call_direction}(inbound) =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->variables] continue=true
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [variables] () =~ // break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->user_record] continue=true
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [user_record] () =~ // break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(user_record=${user_data ${destination_number}@${domain_name} var user_record}) INLINE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(user_record=)
2018-02-13 15:56:19.728335 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [user_record]=[UNDEF]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2018-02-13 15:56:19.728335 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fefd40def90 Connected.
2018-02-13 15:56:19.748336 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fefd40def90 released.
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(from_user_exists=false)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [from_user_exists]=[false]
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [user_record] ${user_exists}(true) =~ /^true$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [user_record] ${call_direction}(inbound) =~ /^inbound$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^outbound$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^local$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->redial] continue=true
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [redial] destination_number(100) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->speed_dial] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [speed_dial] destination_number(100) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->1619.10d] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [1619.10d] destination_number(100) =~ /^(\d{10})$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->1619.11d] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [1619.11d] destination_number(100) =~ /^\+?(\d{11})$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->1619.8d] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [1619.8d] destination_number(100) =~ /^(\d{8})$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->1619.9d] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (FAIL) [1619.9d] destination_number(100) =~ /^(\d{9})$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx parsing [pbx.xxxxxxxxxxxxxxxxxxx.com->1619.d3] continue=false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Regex (PASS) [1619.d3] destination_number(100) =~ /^(\d{3})$/ break=on-false
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(sip_h_X-accountcode=${accountcode})
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(call_direction=outbound)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action unset(call_timeout)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(hangup_after_bridge=true)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(effective_caller_id_name=${outbound_caller_id_name})
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(effective_caller_id_number=${outbound_caller_id_number})
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(inherit_codec=true)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(ignore_display_updates=true)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(callee_id_number=100)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action set(continue_on_fail=true)
Dialplan: sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Action bridge(sofia/gateway/1d9c1c6c-14d9-45b5-a020-512905541a56/100)
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_ROUTING -> CS_EXECUTE
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING going to sleep
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_EXECUTE (Cur 1 Tot 131)
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE
2018-02-13 15:56:19.748336 [DEBUG] mod_sofia.c:198 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA EXECUTE
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:328 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard EXECUTE
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx export(origination_callee_id_name=100)
2018-02-13 15:56:19.748336 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[100]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(RFC2822_DATE=Tue, 13 Feb 2018 15:56:19 +0100)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [RFC2822_DATE]=[Tue, 13 Feb 2018 15:56:19 +0100]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx hash(insert/pbx.xxxxxxxxxxxxxxxxxxx.com-last_dial/3xxxxxxxxxx/100)
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(sip_h_X-accountcode=)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [sip_h_X-accountcode]=[UNDEF]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(call_direction=outbound)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_direction]=[outbound]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx unset(call_timeout)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1693 UNSET [call_timeout]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(hangup_after_bridge=true)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [hangup_after_bridge]=[true]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(effective_caller_id_name=)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [effective_caller_id_name]=[UNDEF]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(effective_caller_id_number=)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [effective_caller_id_number]=[UNDEF]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(inherit_codec=true)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [inherit_codec]=[true]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(ignore_display_updates=true)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [ignore_display_updates]=[true]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(callee_id_number=100)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [callee_id_number]=[100]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(continue_on_fail=true)
2018-02-13 15:56:19.748336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [continue_on_fail]=[true]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx bridge(sofia/gateway/1d9c1c6c-14d9-45b5-a020-512905541a56/100)
2018-02-13 15:56:19.748336 [DEBUG] switch_channel.c:1250 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx EXPORTING[export_vars] [origination_callee_id_name]=[100] to event
2018-02-13 15:56:19.748336 [DEBUG] switch_ivr_originate.c:2142 Parsing global variables
2018-02-13 15:56:19.748336 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/100 [1ea5a29c-d15c-4d29-b846-c529e2e421ae]
2018-02-13 15:56:19.748336 [DEBUG] mod_sofia.c:4819 (sofia/internal/100) State Change CS_NEW -> CS_INIT
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_INIT (Cur 2 Tot 132)
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/100) State INIT
2018-02-13 15:56:19.748336 [DEBUG] mod_sofia.c:90 sofia/internal/100 SOFIA INIT
2018-02-13 15:56:19.748336 [DEBUG] sofia_glue.c:1295 sofia/internal/100 sending invite version: 1.6.20 -37-987c9b9 64bit
Local SDP:
v=0
o=FreeSWITCH 1518516963 1518516964 IN IP4 149.xxx.xxx.xxx
s=FreeSWITCH
c=IN IP4 149.xxx.xxx.xxx
t=0 0
m=audio 16816 RTP/AVP 8 9 0 3 101 13
a=rtpmap:9 G722/8000
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
a=sendrecv
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:40 sofia/internal/100 Standard INIT
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/100) State Change CS_INIT -> CS_ROUTING
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/100) State INIT going to sleep
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_ROUTING (Cur 2 Tot 132)
2018-02-13 15:56:19.748336 [DEBUG] sofia.c:7084 Channel sofia/internal/100 entering state [calling][0]
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/100) State ROUTING
2018-02-13 15:56:19.748336 [DEBUG] mod_sofia.c:143 sofia/internal/100 SOFIA ROUTING
2018-02-13 15:56:19.748336 [DEBUG] switch_ivr_originate.c:67 (sofia/internal/100) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/100) State ROUTING going to sleep
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 132)
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:662 (sofia/internal/100) State CONSUME_MEDIA
2018-02-13 15:56:19.748336 [DEBUG] switch_core_state_machine.c:662 (sofia/internal/100) State CONSUME_MEDIA going to sleep
send 1348 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.677871:
INVITE sip:100@voip.connecting-peoples.com SIP/2.0
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;rport;branch=z9hG4bK3gg89p5ZZHjDa
Max-Forwards: 68
From: "3xxxxxxxxxx" <sip:1619@voip.connecting-peoples.com>;tag=NH13Z25tHNayp
To: <sip:100@voip.connecting-peoples.com>
Call-ID: e4a2639a-8b70-1236-0e87-fa163e15bfd5
CSeq: 118930826 INVITE
Contact: <sip:gw+1d9c1c6c-14d9-45b5-a020-512905541a56@149.xxx.xxx.xxx:5060;transport=udp;gw=1d9c1c6c-14d9-45b5-a020-512905541a56>
Content-Disposition: session
Content-Length: 317
Remote-Party-ID: "3xxxxxxxxxx" <sip:3xxxxxxxxxx@voip.connecting-peoples.com>;party=calling;screen=no;privacy=off
v=0
s=FreeSWITCH
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
recv 567 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.687480:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;branch=z9hG4bK3gg89p5ZZHjDa;received=149.xxx.xxx.xxx;rport=5060
To: <sip:100@voip.connecting-peoples.com>;tag=as455f4232
Server: MOR Softswitch
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="6191915c"
Content-Length: 0
send 357 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.687584:
ACK sip:100@voip.connecting-peoples.com SIP/2.0
Max-Forwards: 68
CSeq: 118930826 ACK
Content-Length: 0
send 1526 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.687861:
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;rport;branch=z9hG4bK4S90Bjp3vt8ZN
Max-Forwards: 68
CSeq: 118930827 INVITE
Authorization: Digest username="1619", realm="asterisk", nonce="6191915c", algorithm=MD5, uri="sip:100@voip.connecting-peoples.com", response="6648637e018730f37df4dbc742e8cded"
Content-Length: 317
v=0
s=FreeSWITCH
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
2018-02-13 15:56:19.768330 [DEBUG] sofia.c:7084 Channel sofia/internal/100 entering state [calling][0]
recv 548 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.699951:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;branch=z9hG4bK4S90Bjp3vt8ZN;received=149.xxx.xxx.xxx;rport=5060
Session-Expires: 1800;refresher=uas
Contact: <sip:100@188.xxx.xxx.xxx:5060>
Content-Length: 0
recv 525 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.726811:
SIP/2.0 403 Forbidden
To: <sip:100@voip.connecting-peoples.com>;tag=as425a0481
Content-Length: 0
send 357 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.726923:
Max-Forwards: 68
CSeq: 118930827 ACK
Content-Length: 0
2018-02-13 15:56:19.808331 [DEBUG] sofia.c:7084 Channel sofia/internal/100 entering state [terminated][403]
2018-02-13 15:56:19.808331 [NOTICE] sofia.c:8273 Hangup sofia/internal/100 [CS_CONSUME_MEDIA] [CALL_REJECTED]
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_HANGUP (Cur 2 Tot 132)
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/100) Callstate Change DOWN -> HANGUP
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/100) State HANGUP
2018-02-13 15:56:19.808331 [DEBUG] mod_sofia.c:438 Channel sofia/internal/100 hanging up, cause: CALL_REJECTED
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:60 sofia/internal/100 Standard HANGUP, cause: CALL_REJECTED
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/100) State HANGUP going to sleep
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/100) State Change CS_HANGUP -> CS_REPORTING
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_REPORTING (Cur 2 Tot 132)
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/100) State REPORTING
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:174 sofia/internal/100 Standard REPORTING, cause: CALL_REJECTED
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/100) State REPORTING going to sleep
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/100) State Change CS_REPORTING -> CS_DESTROY
2018-02-13 15:56:19.808331 [DEBUG] switch_core_session.c:1665 Session 132 (sofia/internal/100) Locked, Waiting on external entities
2018-02-13 15:56:19.808331 [DEBUG] switch_ivr_originate.c:3848 Originate Resulted in Error Cause: 21 [CALL_REJECTED]
2018-02-13 15:56:19.808331 [INFO] mod_dptools.c:3436 Originate Failed. Cause: CALL_REJECTED
2018-02-13 15:56:19.808331 [NOTICE] switch_core_state_machine.c:385 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx has executed the last dialplan instruction, hanging up.
2018-02-13 15:56:19.808331 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [CS_EXECUTE] [NORMAL_CLEARING]
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE going to sleep
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_HANGUP (Cur 2 Tot 132)
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Callstate Change RINGING -> HANGUP
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State HANGUP
2018-02-13 15:56:19.808331 [DEBUG] mod_sofia.c:432 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Overriding SIP cause 480 with 403 from the other leg
2018-02-13 15:56:19.808331 [DEBUG] mod_sofia.c:438 Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx hanging up, cause: NORMAL_CLEARING
2018-02-13 15:56:19.808331 [DEBUG] mod_sofia.c:577 Responding to INVITE with: 403
send 884 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.729372:
Max-Forwards: 69
To: <sip:gw+1d9c1c6c-14d9-45b5-a020-512905541a56@149.xxx.xxx.xxx:5060;transport=udp3>;tag=m87ay7mQmcmBB
Call-ID:
CSeq: 102 INVITE
Accept: application/sdp
Content-Length: 0
Remote-Party-ID: "100" <sip:100@149.xxx.xxx.xxx>;party=calling;privacy=off;screen=no
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:60 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard HANGUP, cause: NORMAL_CLEARING
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State HANGUP going to sleep
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_HANGUP -> CS_REPORTING
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_REPORTING (Cur 2 Tot 132)
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State REPORTING
2018-02-13 15:56:19.808331 [NOTICE] switch_core_session.c:1683 Session 132 (sofia/internal/100) Ended
2018-02-13 15:56:19.808331 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/100 [CS_DESTROY]
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/100) Running State Change CS_DESTROY (Cur 1 Tot 132)
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/100) State DESTROY
2018-02-13 15:56:19.808331 [DEBUG] mod_sofia.c:343 sofia/internal/100 SOFIA DESTROY
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:181 sofia/internal/100 Standard DESTROY
2018-02-13 15:56:19.808331 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/100) State DESTROY going to sleep
recv 524 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:20.740017:
ACK sip:gw+1d9c1c6c-14d9-45b5-a020-512905541a56@149.xxx.xxx.xxx:5060;transport=udp SIP/2.0
Max-Forwards: 70
Call-ID:
CSeq: 102 ACK
Content-Length: 0
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:174 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard REPORTING, cause: NORMAL_CLEARING
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State REPORTING going to sleep
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_REPORTING -> CS_DESTROY
2018-02-13 15:56:19.928336 [DEBUG] switch_core_session.c:1665 Session 131 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Locked, Waiting on external entities
2018-02-13 15:56:19.928336 [NOTICE] switch_core_session.c:1683 Session 131 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Ended
2018-02-13 15:56:19.928336 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [CS_DESTROY]
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_DESTROY (Cur 0 Tot 132)
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State DESTROY
2018-02-13 15:56:19.928336 [DEBUG] mod_sofia.c:343 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA DESTROY
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:181 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard DESTROY
2018-02-13 15:56:19.928336 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State DESTROY going to sleep
recv 1118 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.004518:
Via: SIP/2.0/UDP 188.xxx.xxx.xxx:5060;branch=z9hG4bK0a9a98ac;rport
Max-Forwards: 70
From: "3xxxxxxxxxx" <sip:3xxxxxxxxxx@188.xxx.xxx.xxx>;tag=as76cb24eb
Call-ID:
4351efb011df5b0e1db26b363e931d2c@188.xxx.xxx.xxx:5060
CSeq: 102 INVITE
Date: Tue, 13 Feb 2018 14:56:21 GMT
Content-Length: 314
v=0
o=root 1272098580 1272098580 IN IP4 188.xxx.xxx.xxx
t=0 0
m=audio 10906 RTP/AVP 8 18 0 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
send 374 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.004804:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 188.xxx.xxx.xxx:5060;branch=z9hG4bK0a9a98ac;rport=5060
Call-ID:
CSeq: 102 INVITE
Content-Length: 0
2018-02-13 15:56:21.088349 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [34e9a018-3464-489d-81b2-d0aefa2f9020]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_NEW (Cur 1 Tot 133)
2018-02-13 15:56:21.088349 [DEBUG] sofia.c:9873 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx receiving invite from 188.xxx.xxx.xxx:5060 version: 1.6.20 -37-987c9b9 64bit
2018-02-13 15:56:21.088349 [DEBUG] sofia.c:9989 IP 188.xxx.xxx.xxx Approved by acl "domains[]". Access Granted.
2018-02-13 15:56:21.088349 [DEBUG] sofia.c:7084 Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx entering state [received][100]
2018-02-13 15:56:21.088349 [DEBUG] sofia.c:7094 Remote SDP:
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[GSM:3:8000:20:13200:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:3061 Set Codec sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx PCMA/8000 20 ms 160 samples 64000 bits 1 channels
2018-02-13 15:56:21.088349 [DEBUG] switch_core_codec.c:111 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Original read codec set to PCMA:8
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
2018-02-13 15:56:21.088349 [DEBUG] switch_core_media.c:4767 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Set 2833 dtmf send payload to 101 recv payload to 101
2018-02-13 15:56:21.088349 [DEBUG] sofia.c:7507 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_NEW -> CS_INIT
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State NEW
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_INIT (Cur 1 Tot 133)
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State INIT
2018-02-13 15:56:21.088349 [DEBUG] mod_sofia.c:90 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA INIT
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:40 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard INIT
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_INIT -> CS_ROUTING
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State INIT going to sleep
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_ROUTING (Cur 1 Tot 133)
2018-02-13 15:56:21.088349 [DEBUG] switch_channel.c:2249 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Callstate Change DOWN -> RINGING
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING
2018-02-13 15:56:21.088349 [DEBUG] mod_sofia.c:143 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA ROUTING
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:236 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard ROUTING
2018-02-13 15:56:21.088349 [INFO] mod_dialplan_xml.c:637 Processing 3xxxxxxxxxx <3xxxxxxxxxx>->1619 in context public
2018-02-13 15:56:21.088349 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_direction]=[inbound]
2018-02-13 15:56:21.088349 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [domain_uuid]=[9f28c57f-5bb1-4b77-9540-170aaf3655aa]
2018-02-13 15:56:21.088349 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [domain_name]=[pbx.xxxxxxxxxxxxxxxxxxx.com]
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_ROUTING -> CS_EXECUTE
2018-02-13 15:56:21.088349 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING going to sleep
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_EXECUTE (Cur 1 Tot 133)
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE
2018-02-13 15:56:21.108339 [DEBUG] mod_sofia.c:198 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA EXECUTE
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:328 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard EXECUTE
2018-02-13 15:56:21.108339 [DEBUG] switch_ivr.c:2165 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_EXECUTE -> CS_ROUTING
2018-02-13 15:56:21.108339 [NOTICE] switch_ivr.c:2172 Transfer sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx to XML[100@pbx.xxxxxxxxxxxxxxxxxxx.com]
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE going to sleep
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_ROUTING (Cur 1 Tot 133)
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING
2018-02-13 15:56:21.108339 [DEBUG] mod_sofia.c:143 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA ROUTING
2018-02-13 15:56:21.108339 [DEBUG] switch_core_state_machine.c:236 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard ROUTING
2018-02-13 15:56:21.108339 [INFO] mod_dialplan_xml.c:637 Processing 3xxxxxxxxxx <3xxxxxxxxxx>->100 in context pbx.xxxxxxxxxxxxxxxxxxx.com
2018-02-13 15:56:21.108339 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [user_exists]=[true]
2018-02-13 15:56:21.108339 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [extension_uuid]=[121c9bc6-d594-4fcc-b3cc-dcba7ca028df]
2018-02-13 15:56:21.128341 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [hold_music]=[local_stream://default]
2018-02-13 15:56:21.128341 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_all_enabled]=[false]
2018-02-13 15:56:21.128341 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_all_destination]=[UNDEF]
2018-02-13 15:56:21.128341 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_busy_enabled]=[false]
2018-02-13 15:56:21.128341 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_busy_destination]=[UNDEF]
2018-02-13 15:56:21.148338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_no_answer_enabled]=[false]
2018-02-13 15:56:21.148338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_no_answer_destination]=[UNDEF]
2018-02-13 15:56:21.148338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_user_not_registered_enabled]=[false]
2018-02-13 15:56:21.148338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [forward_user_not_registered_destination]=[UNDEF]
2018-02-13 15:56:21.148338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [do_not_disturb]=[false]
2018-02-13 15:56:21.148338 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_timeout]=[30]
2018-02-13 15:56:21.168337 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [missed_call_app]=[UNDEF]
2018-02-13 15:56:21.168337 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [missed_call_data]=[UNDEF]
2018-02-13 15:56:21.168337 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [toll_allow]=[UNDEF]
2018-02-13 15:56:21.168337 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_screen_enabled]=[false]
2018-02-13 15:56:21.168337 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [user_record]=[UNDEF]
2018-02-13 15:56:21.168337 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fefd40def90 Connected.
2018-02-13 15:56:21.168337 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fefd40def90 released.
2018-02-13 15:56:21.168337 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [from_user_exists]=[false]
2018-02-13 15:56:21.168337 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_ROUTING -> CS_EXECUTE
2018-02-13 15:56:21.168337 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State ROUTING going to sleep
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_EXECUTE (Cur 1 Tot 133)
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE
2018-02-13 15:56:21.188336 [DEBUG] mod_sofia.c:198 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA EXECUTE
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:328 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard EXECUTE
2018-02-13 15:56:21.188336 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[100]
EXECUTE sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx set(RFC2822_DATE=Tue, 13 Feb 2018 15:56:21 +0100)
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [RFC2822_DATE]=[Tue, 13 Feb 2018 15:56:21 +0100]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [sip_h_X-accountcode]=[UNDEF]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [call_direction]=[outbound]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1693 UNSET [call_timeout]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [hangup_after_bridge]=[true]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [effective_caller_id_name]=[UNDEF]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [effective_caller_id_number]=[UNDEF]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [inherit_codec]=[true]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [ignore_display_updates]=[true]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [callee_id_number]=[100]
2018-02-13 15:56:21.188336 [DEBUG] mod_dptools.c:1548 SET sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [continue_on_fail]=[true]
2018-02-13 15:56:21.188336 [DEBUG] switch_channel.c:1250 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx EXPORTING[export_vars] [origination_callee_id_name]=[100] to event
2018-02-13 15:56:21.188336 [DEBUG] switch_ivr_originate.c:2142 Parsing global variables
2018-02-13 15:56:21.188336 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/100 [91a69f18-468c-402b-8fbd-40a8787c5131]
2018-02-13 15:56:21.188336 [DEBUG] mod_sofia.c:4819 (sofia/internal/100) State Change CS_NEW -> CS_INIT
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_INIT (Cur 2 Tot 134)
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/100) State INIT
2018-02-13 15:56:21.188336 [DEBUG] mod_sofia.c:90 sofia/internal/100 SOFIA INIT
2018-02-13 15:56:21.188336 [DEBUG] sofia_glue.c:1295 sofia/internal/100 sending invite version: 1.6.20 -37-987c9b9 64bit
Local SDP:
v=0
o=FreeSWITCH 1518512457 1518512458 IN IP4 149.xxx.xxx.xxx
s=FreeSWITCH
t=0 0
m=audio 21324 RTP/AVP 8 9 0 3 101 13
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
a=sendrecv
send 1348 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.097449:
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;rport;branch=z9hG4bK522SDD76S3yjH
Max-Forwards: 68
From: "3xxxxxxxxxx" <sip:1619@voip.connecting-peoples.com>;tag=Q3KN3r71B7p3D
Call-ID: e57c8a35-8b70-1236-0e87-fa163e15bfd5
Content-Length: 317
v=0
s=FreeSWITCH
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:40 sofia/internal/100 Standard INIT
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/100) State Change CS_INIT -> CS_ROUTING
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/100) State INIT going to sleep
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_ROUTING (Cur 2 Tot 134)
2018-02-13 15:56:21.188336 [DEBUG] sofia.c:7084 Channel sofia/internal/100 entering state [calling][0]
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/100) State ROUTING
2018-02-13 15:56:21.188336 [DEBUG] mod_sofia.c:143 sofia/internal/100 SOFIA ROUTING
2018-02-13 15:56:21.188336 [DEBUG] switch_ivr_originate.c:67 (sofia/internal/100) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/100) State ROUTING going to sleep
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 134)
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:662 (sofia/internal/100) State CONSUME_MEDIA
2018-02-13 15:56:21.188336 [DEBUG] switch_core_state_machine.c:662 (sofia/internal/100) State CONSUME_MEDIA going to sleep
recv 567 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.106997:
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;branch=z9hG4bK522SDD76S3yjH;received=149.xxx.xxx.xxx;rport=5060
To: <sip:100@voip.connecting-peoples.com>;tag=as31f1ad98
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="347d8ae8"
Content-Length: 0
send 357 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.107072:
Max-Forwards: 68
CSeq: 118930827 ACK
Content-Length: 0
send 1526 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.107292:
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;rport;branch=z9hG4bK6BvjF8QaQcN5c
Max-Forwards: 68
CSeq: 118930828 INVITE
Authorization: Digest username="1619", realm="asterisk", nonce="347d8ae8", algorithm=MD5, uri="sip:100@voip.connecting-peoples.com", response="26bad2591c2279333b76ffb40ab4043c"
Content-Length: 317
v=0
s=FreeSWITCH
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
recv 548 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.117491:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 149.xxx.xxx.xxx;branch=z9hG4bK6BvjF8QaQcN5c;received=149.xxx.xxx.xxx;rport=5060
Content-Length: 0
recv 525 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.137928:
To: <sip:100@voip.connecting-peoples.com>;tag=as469ff0ce
Content-Length: 0
send 357 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.138002:
Max-Forwards: 68
CSeq: 118930828 ACK
Content-Length: 0
2018-02-13 15:56:21.228331 [DEBUG] sofia.c:7084 Channel sofia/internal/100 entering state [terminated][403]
2018-02-13 15:56:21.228331 [NOTICE] sofia.c:8273 Hangup sofia/internal/100 [CS_CONSUME_MEDIA] [CALL_REJECTED]
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_HANGUP (Cur 2 Tot 134)
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/100) Callstate Change DOWN -> HANGUP
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/100) State HANGUP
2018-02-13 15:56:21.228331 [DEBUG] mod_sofia.c:438 Channel sofia/internal/100 hanging up, cause: CALL_REJECTED
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:60 sofia/internal/100 Standard HANGUP, cause: CALL_REJECTED
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/100) State HANGUP going to sleep
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/100) State Change CS_HANGUP -> CS_REPORTING
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/100) Running State Change CS_REPORTING (Cur 2 Tot 134)
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/100) State REPORTING
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:174 sofia/internal/100 Standard REPORTING, cause: CALL_REJECTED
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/100) State REPORTING going to sleep
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/100) State Change CS_REPORTING -> CS_DESTROY
2018-02-13 15:56:21.228331 [DEBUG] switch_core_session.c:1665 Session 134 (sofia/internal/100) Locked, Waiting on external entities
2018-02-13 15:56:21.228331 [DEBUG] switch_ivr_originate.c:3848 Originate Resulted in Error Cause: 21 [CALL_REJECTED]
2018-02-13 15:56:21.228331 [INFO] mod_dptools.c:3436 Originate Failed. Cause: CALL_REJECTED
2018-02-13 15:56:21.228331 [NOTICE] switch_core_state_machine.c:385 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx has executed the last dialplan instruction, hanging up.
2018-02-13 15:56:21.228331 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [CS_EXECUTE] [NORMAL_CLEARING]
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State EXECUTE going to sleep
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_HANGUP (Cur 2 Tot 134)
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Callstate Change RINGING -> HANGUP
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State HANGUP
2018-02-13 15:56:21.228331 [DEBUG] mod_sofia.c:432 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Overriding SIP cause 480 with 403 from the other leg
2018-02-13 15:56:21.228331 [DEBUG] mod_sofia.c:438 Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx hanging up, cause: NORMAL_CLEARING
2018-02-13 15:56:21.228331 [DEBUG] mod_sofia.c:577 Responding to INVITE with: 403
send 884 bytes to udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.139973:
Max-Forwards: 69
To: <sip:gw+1d9c1c6c-14d9-45b5-a020-512905541a56@149.xxx.xxx.xxx:5060;transport=udp3>;tag=pttv1Xpyey0gj
Call-ID:
CSeq: 102 INVITE
Content-Length: 0
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:60 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard HANGUP, cause: NORMAL_CLEARING
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State HANGUP going to sleep
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_HANGUP -> CS_REPORTING
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_REPORTING (Cur 2 Tot 134)
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State REPORTING
2018-02-13 15:56:21.228331 [NOTICE] switch_core_session.c:1683 Session 134 (sofia/internal/100) Ended
2018-02-13 15:56:21.228331 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/100 [CS_DESTROY]
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/100) Running State Change CS_DESTROY (Cur 1 Tot 134)
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/100) State DESTROY
2018-02-13 15:56:21.228331 [DEBUG] mod_sofia.c:343 sofia/internal/100 SOFIA DESTROY
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:181 sofia/internal/100 Standard DESTROY
2018-02-13 15:56:21.228331 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/100) State DESTROY going to sleep
recv 524 bytes from udp/[188.xxx.xxx.xxx]:5060 at 15:56:22.149328:
Max-Forwards: 70
Contact: <sip:3xxxxxxxxxx@188.xxx.xxx.xxx:5060>
Call-ID:
CSeq: 102 ACK
User-Agent: MOR Softswitch
Content-Length: 0
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:174 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard REPORTING, cause: NORMAL_CLEARING
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State REPORTING going to sleep
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State Change CS_REPORTING -> CS_DESTROY
2018-02-13 15:56:21.368334 [DEBUG] switch_core_session.c:1665 Session 133 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Locked, Waiting on external entities
2018-02-13 15:56:21.368334 [NOTICE] switch_core_session.c:1683 Session 133 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Ended
2018-02-13 15:56:21.368334 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx [CS_DESTROY]
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) Running State Change CS_DESTROY (Cur 0 Tot 134)
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State DESTROY
2018-02-13 15:56:21.368334 [DEBUG] mod_sofia.c:343 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx SOFIA DESTROY
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:181 sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx Standard DESTROY
2018-02-13 15:56:21.368334 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/3xxxxxxxxxx@188.xxx.xxx.xxx) State DESTROY going to sleep
freeswitch@vpsXXXXXX.ovh.net> sofia global siptrace off
+OK Global siptrace off
freeswitch@vpsXXXXXX.ovh.net> /bye
root@vpsXXXXXX:~#
