System application missing
mrjoli021
128
We have some custom scripts that ran on older versions. We have just installed version 4.5.15. These scripts are python scripts, we used to call them with the "system" action. We are are not seeing the system application anymore. Is there a way to add this back, or is there a new alternative?
imitearc
I have same issue: "Dialplan application "system" is missing". How can we fix it.
Thank you.
imitearc
I contacted Goose2600 but I did not get any reply yet.
imitearc
Hi everyone,
system has been disabled for security reasons.
Highly recommended move your script file to /var/www/fusionpbx and then use “curl” instead of system, “curl” is fastest and more secure.
Example: copy or move the script_file.sh or script_file.php or etc. to /var/www/fusionpbx/
(tag: "action" | Type: "curl" | Data: "http://127.0.0.1/script_file.sh")
Or
(tag: "action" | Type: "curl" | Data: "http://127.0.0.1/script_file.php")
Good lock
