Transcribing voicemails
rubberducky
51
I went in and edited /usr/share/freeswitch/scripts/app/voicemail/resources/functions/record_message.lua so my voicemails can be transcribed via Azure. Everything works great for a day, then record_message.lua gets overwritten with the original file. So, I copy the edited one again, and sure enough within about 24 hours it gets overwritten again.
As a stopgap I've simply started a cronjob to keep recopying the edited file, but I'd like to find out how I can make my changes permanent. Any advice?
Not seen this happen before, unless you are upgrading / running app_defaults etc. I have a few modified lua scripts and they don't get overwritten. What version of Fusion are you using?
You could try changing the permissions on the file so it is readable by everyone but only writable by root.
