Transfer Calls between ATA Ext and Deskphone
CrzyGK
I am trying to figure out how I can transfer calls from an Analog Extension (provided by a Grandstream HT802) to a regular desk phone (such as a gxp1608) when both are connected to FusionPBX. I have been through the settings on the HT802 to see if there is any functionality that I can do with the flash key on the analog phone, but I'm not having any luck getting this to work.
Any help would be greatly appreciated.
Thanks!
Dan
46
12
*1<extension> should transfer a call, last I tested it that worked for transferring calls to any extension inside a domain from a HT802.
We have labels that list extensions and feature codes for users on analog ATAs & cordless Grandstream DP720 phones, I'd get complaints if *1 didn't work :p
Reactions: JamesBorne
Andrew Byrd
259
Did you get the HT802 to auto provision ok? I have tried to use provisioning and it never provisions.
I logged into my ht802, inserted my provisioning URL
http://mydomain.com/app/provision
Saved,rebooted
Then went to Fusion, set up the ext, device mac etc... and clicked provision.
Then I rebooted the ATA and it never provisioned
Any ideas?
