Trying to get FusionPBX working, Newbi questions
You need another condition for each outbound route to match the extension. This way the dialplan selects the route that matches this condition and skips all others.
Also, to be clear, I understand your use case and why you are doing it. But this is not a standard practice. Usually, users share an outbound gateway. I just want to make sure you are building the system correctly. Perhaps the approach you chose to accommodate is not the best practice.
Also, I'm not affiliated with FusionPBX. I'm just simply trying to help.
Thanks @pbxgeek , I appreciate your help.
I'ts a bit like a retirement home, they can call internal together but also have their own in- and outbound route.
So I need to add a condition to every outbound route. Can you tell me how this condition should look like?
Do they have their own VoIP service that you don't provide?
Your outbound route would look like this. I added a condition to check if the call was from extension 1003. Then this outbound route can only be used by this extension
Great, that works!
is it possible to have a range of numbers? For example, extensions 100 to 105 can use the same route.
We all have our own account on Cheapconnect, a Dutch prepaid voip provider. So everyone has his own trunk.
I also need to create a route to call the emergency number. In The Netherlands it's 112 instead of 911. Can I just change (^911$|^933$) to (^112$|^933$) in the dialplan? What does the 933 stand for? Is there anything else I have to think about?
yes you can definitely add a range if you play with regex.
Yes, you can update 911 to 112, like in your example. 933 is a test for 911 in US.
The caller_id_number as suggested would work. The caller ID is easier to change and this makes it a less secure option. Another option you can use ${sip_from_user}
In place of the condition for caller_id_number just exchange caller_id_number with ${sip_from_user}
Thanks, I will change it.
Yesterday I made my first IVR, Call Flow, Call Center. Works like a charm. I was wondering, is there some option to have the caller hear a message/recording and then to another destination like a VMbox/IVR/Call FLow or anything else?
I also would like to have my fusionpbx talk Dutch. I found this thread:
Unfortunately, I really don't understand what to do, at all. Is someone willing to guide me step by step?
Thanks to you all for helping!
