Variable Gateway Data
mark.milton
22
Hope someone can help, my SIP Trunks require the connection to be outbound-number@siptrunkdomain.com which it gets the outbound number from the username field within the Gateway.
Is there a way to make the outbound variable such as using the extensions caller ID
The Data column within SIP Status shows with whatever number as before the @ shows as the caller ID to the receiver
566
Set caller id in from to true in gateway advanced settings. Don't for get to stop and start the gateway after changes.
