Hi
We have a 2N IP BASE doorbell set-up in Fusionpbx and it works great. You know the usual video, switch to open a door,...
Atm the 2N is configured using the local IP so the video doesn't go through our VOIP only the audio. Now they want to see video from outside of the local network so the video needs to be sent through our VOIP gateway.
What settings need to be enabled to make this work? Only adding the H264 to the switch variables codecs? Does this use webrtc (doubt it)?
Can't seem to find anything in https://docs.fusionpbx.com/
Running FusionPBX 5.0.1 and Switch 1.10.7 (64bit)
Thanks!
Thanks!
