New to the pbx but seem to have issues with mailboxes
The greeting plays and then it says there is an error contact your administrator and the it plays the instructions. If you leave a voicemail that bit all works fine
I was hoping I could just add skip_instructions = true in the variables like I used to in fusionpbx but this did not work.
Just getting rid of the message that says error contact your administrator would be good.
I built a 2nd box just incase I had screwed something up but the same
