SOLVED Voicemail # of Rings
Frank
61
Is there a way to set, by extension, the number of rings before going to voicemail?
Please be aware that when I last checked this same time out applies to outbound calls too, a retarded move IMHO that should be reversed.
Frank
61
Hi Daz,
I tried it out and it seems work. I set one extension "A" to 15 sec and left the other "B" to 30 sec. I called from "A" to "B" and the call went to voicemail after 6 rings. I called from "B" to "A" and it went to voicemail after 3 rings. They must have changed the functionality.
