Voicemail Transcription Issues after 5.4 Upgrade
UCtech
42
Have not been able to get transcribe working after upgrading from 5.3 to 5.4. Voicemail to email is still working but where the transcription normally is located instead just shows ${message_text}. Was working fine before the upgrade. Using Watson. Transcribe queue shows nothing. Have tested in shell that it is running using systemctl status email_queue as follows:
root@xxxxx:~# systemctl status transcribe_queue
● transcribe_queue.service - Audio Transcribe Queue Service
Loaded: loaded (/etc/systemd/system/transcribe_queue.service; enabled; preset: enabled)
Active: active (running) since Wed 2025-12-17 15:03:35 CST; 12min ago
Main PID: 604 (php)
Tasks: 1 (limit: 9385)
Memory: 15.8M
CPU: 314ms
CGroup: /system.slice/transcribe_queue.service
└─604 /usr/bin/php /var/www/fusionpbx/app/transcribe/resources/service/transcribe_queue.php
Dec 17 15:03:35 UAU-VoIP systemd[1]: Started transcribe_queue.service - Audio Transcribe Queue Service.
Dec 17 15:03:37 UAU-VoIP php[604]: PHP Warning: file_put_contents(/tmp/autoloader_interface_cache.php): Failed to open stream: Permission denied in /var/www/fusionpbx/resources/classes/a>
Dec 17 15:03:37 UAU-VoIP php[604]: [NOTICE] Starting up...
For the upgrade I followed the steps in 5.3 to 5.4 here:
All of that went well but not sure what the "Domains member feature" is or where the "application manager" is so I did nothing with that part of the upgrade. Could that be part of the problem?
How do I fix the "Failed to open stream: Permission denied"?
Thanks in advance!
Sorry didn't see the warning line was truncated. The full warning is:
Failed to open stream: Permission denied in /var/www/fusionpbx/resources/classes/auto_loader.php on line 208
auto_loader.php line 208 is:
$interface_result = file_put_contents(self::$interfaces_file, "<?php\n return " . $interfaces_array . ";\n");
