VoiP to Analog Paging Horns
robert
We are using fusionpbx along with a Cisco SPA112, We can get it to ring the device, but it does not auto-pickup/page/audio.
On our older analog phone system we would put it to a "voice path".
Any ideas?
Chidado
50
Are you using the page code in the Dialplan Manager?
Have you searched to see if the Cisco SPA112 has an auto answer set?
robert
I am trying you use the "page code", I programmed an extension on the CISCO SPA112-port 1 ( x1200 ).
Per your suggestion, I looked harder at the SPA112 settings and fours a setting the designates itself as a Streaming Audio Port.
If I have an analog phone off the hook, this all works fine, I can call x1200 and without ringing, I am talking to that person. The problem I am running into still is taht the paging horn cant pick up the call automatically, etc. :(
Has anybody out there setup paging horns using something like the CISCO SPA112?
Thanks for the support.
