xml_cdr calls delete
goose2600
51
I noticed cannot delete calls from the xml_cdr app in a fresh Fusionpbx install, but in my old installation was possible.
Is there a setting somewere to enable this feature?
Thanks!
Have a look in Advanced->Group manager and click on the permissions link for superadmin.
There are quite a few relatively new permissions for CDRs, you probably need xml_cdr_delete.
Reactions: goose2600
Andrew Byrd
309
I tried to check xml_cdr_delete for the group "user" and it allows me to check it but when I hit save it reverts back to unchecked.
Any ideas?
@Andrew Byrd I have seen this behavior before, I'm struggling to remember what caused it now. I think it may have been something to do with the group_uuid being blank in the v_group_permissions table.
I have just added the xml_cdr_delete permission to group user on one of my test boxes and it worked fine, but I did notice that superadmin already had this permission and if I tried to remove it by unchecking the box, after I hit save the check came back.
So I issued the following query:
select * from v_group_permissions where permission_name = 'xml_cdr_delete';
And this was the result:
        group_permission_uuid         | domain_uuid | permission_name | group_name |              group_uuid
f74457ad-7002-4972-b3e6-0464a0077986 |             | xml_cdr_delete  | superadmin |
6ce22e8d-a68c-4bf6-8fd7-24ac0b229925 |             | xml_cdr_delete  | user       | 41ae078a-7042-4f4d-9d94-e361f612c245
(2 rows)
As you can see group_uuid is null for superadmin, so maybe this could be the reason, but as I said I really cannot remember.
Ok, I tried this out on my test box for you. This worked for me, but also bear in mind that running Update - App Defaults may also fix the issue, but I have not tried that. I tend to avoid App Defaults as much as possible - don't ask me why.
First (in my case) i needed to find out the uuid of the superadmin group:
select * from v_groups where group_name = 'superadmin';
Result:
              group_uuid              | domain_uuid | group_name | group_protected |     group_description     | group_level
 92e77a3b-95dc-44ce-bfbd-66e56c18010f |             | superadmin | false           | Super Administrator Group |          80
(1 row)
Now using the uuid, I update the v_group_permissions table:
update v_group_permissions set group_uuid = '92e77a3b-95dc-44ce-bfbd-66e56c18010f' where group_name = 'superadmin' and permission_name = 'xml_cdr_delete';
Now the xml_cdr_delete entries look like this:
 9a885249-abd3-45ab-8311-19e07dadec72 |             | xml_cdr_delete  | superadmin | 92e77a3b-95dc-44ce-bfbd-66e56c18010f
(2 rows)
Now when I check or uncheck the xml_cdr_delete permission for superadmin it works!
