Yealink Call Quality
Incubugs
175
Has anyone found that using the latest freeswitch 1.10.3 and up with yealink phones that they are getting jitter speech and even simple things like calling the voicemail the prompts are sounding a bit jittery too ? we have 4 different installs where this seems to be happening and i cant seem to fix it ..
Any ideas ?
andycol
47
14
Any ideas ?
which codec are you using, as i know someone having exact same issue
Incubugs
175
We are using PCMA and we was using g722 but it was worse with that active. Prompts seem to sound better using opus however the transposing when dialing out is alot especially as these are vm
Incubugs
175
This is definitely something to do with the new freeswitch version.. is everybody now using 1.10 or are you guys still using 1.8.7 ? i didnt have any of these issues on 1.8.7
andycol
47
14
our issue turned out not to be yealink related and we are running 3000+- yealinks
are you 100% sure it is the yealink
have you enabled rport?
sip tcp or udp?
Incubugs
175
Thanks for your reply m8,
rport is on and the phones are showing tcp in the registrations page ... What did your issue turn out to be, its driving me nuts
andycol
47
14
ours turned out to be queuemetrics hurting the server
change to udp and see if it helps
andycol
47
14
would be under the extension setting on the actual phone if i remember correct
also have you taken some sip traces
