Yealink Phones Issue
johnny
30
So ordered a few Yealink phones to test with FusionPBX since we have been using Polycoms for awhile now
Set I set them up for provisioning started using them but i noticed an odd thing when you dial a number you cant hear the other side unless you speak into the handset.
I also updated to the latest firmware with still no luck 3 different yealink phone all same issue. T44w
I don't have this problem with my Polycom phones with provisioning
Is this a known bug
Using the latest FusionPBX and Freeswitch.
Any help will be much apprecited
Found it, I must of installed Fusiopnpbx before this option became default so i set to 0 works fantastic now
Advanced → Default Settings → Provision → yealink_voice_vad
Set value to 0 (disabled)
