attended transfer to gateway
leandrodes87
20
Hy Guys
I need help about attended transfer, by default in my fusionpbx 4.5.12 this don't work.
I searched here and i find solution for attended transfer, but this solution function only to attended transfer to internal extension.
I need to transfer to external number, for example "sip trunk" "gateway", my outbound routes is ok, because in this same extension that use for test, i call for this gateway using outbound route.
i have this prints that i change dialplain in bind_digit_action and att_xfer.
NOTE: I can transfer to external number using blind transfer code *1 that is ok. only using attended transfer code *4 have error.
Jul 14, 2020
32
Singapore
www.zionengage.me
@leandrodes87 I tried as to your setting, nothing work for me.
i do the following (see screenshot) and *4 attended transfer work but not honouring follow me. That means it reached the internal extension but will not dial to external number ini follow me or in call forward setting.
action="bind_meta_app"
data="4 b s execute_extension::att_xfer XML ${context}"
I am still hoping someone able to help us here.
