Hi, I am having problems with call forwards with fusionpbx, I have many clients,hotels, etc.. to whom it works correctly, but from one client in particular the call forwards do not work the server (cloud) is programmed in the same way as the others who do not have this problem.
In practice, an external call arrives directed to a ring group. If I add a call forward to a mobile number on the ring group I call from outside and hear the occupied tone the logs are not very helpful it seems that the call is correctly forwarded even if I then get an error 480. If i add a call forward to an extension inside ring group example 400 the other extension ringing correctly in active call, i see the call 400 going versus the cellphone number but it not ring. Another strange thing is: if i call example extension 400 from another extension (421) the call forward working correctly.
I attach the logs.
Thanks for any help or advice I just don't know where the problem might be.
I attach the logs.
