Call forwarding not working in call center module
Aashish sharma
25
I am using fusionpbx version 4.5
I want to forward the call through the call center module. But call forwarding is not working and follow is not working.
Without using softphone.
I don't know There might be a configuration problem
Please guide me.. how can I fix it
Call center bridges the call direct to the end point. If you know that then you may understand why call forward doesn't work with call center. Only way it could follow the forward is using loopback but this will give you other problems like it disregarding some of the other settings you want it to use.
