Calls to Local Users Not passing
Naveed Ur Rehman
I have installed the fusion pbx on my digital ocean server, I have created one user in domain, and user is able to register with freeswitch server. Now problem is that when we call that user, in freeswitch logs, we get the following error
[DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7f09881ca5b0 Connected.
2018-02-01 12:43:48.366183 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7f09881ca5b0 released.
2018-02-01 12:43:48.366183 [WARNING] mod_dptools.c:4184 Can't find user [188881@freeswitch.local]
Even i can see that user is registerd and its reachable when i check using
sofia status profile internel reg
Call-ID: 4221d0a8e409edbac784f8f0dc3eee00@192.168.1.120
User: 188881@xxx.xxx.xxx.xxx
Contact: "" <sip:188881@192.168.1.120:5060;fs_nat=yes;fs_path=sip%3A188881%4014.201.170.242%3A5060>
Agent: 516 V5.0 r1834 b1120
Status: Registered(UDP-NAT)(unknown) EXP(2018-02-01 12:47:42) EXPSECS(172)
Ping-Status: Reachable
Ping-Time: 431.51
Host: fusionpbx
IP: 14.201.170.242
Port: 5060
Auth-User: 188881
Auth-Realm: xxx.xxx.xxx.xxx
MWI-Account: 188881@ xxx.xxx.xxx.xxx
Please advise why this is happening. If i remove this server and reinstall it again, it will start working and after some time it again start giving this error. I can see what working copy of fusion pbx has ${domain} variable set where faulty version has ${domain} variable is empty. I suspect there is some issue LUA scripts.
Regards
Naveed
