Extension Condition Call Forward does not work
Edson
59
Dear,
Regarding a FusionPBX 4.5 Installation.
The Extension Condition Call Forward does not work if the calls arrives from a RingGroup. If call arrives directly on the extension itself, it works properly, it reaches the final destination.
What can i be missing? Is it a bug?
1-This is the RingGroup Strategy setup. There is only one extension, but the same behavior happens with multiple extensions.
2- Conditions call forwards setup
197
This is expected behavior. It is common for a ring group to not follow a member’s forwarding or follow me settings since usually there are other members available to take the call.
in Ring Groups there are options called “ Call Forward” and “Follow Me” with true/false setting. The default is “false” and exhibits the behavior you see.
Set Call Forward to true and calls will follow your extension call forwarding settings.
Reactions: mcs3ss2
Edson
59
@ad5ou Thanks so very much. It makes sense at all.
Yes, it is possible to forward to an alternate destination.
