Hello Team I am using Panasonic since long time and just started using fusionpbx as a hosted solution we have couple 100 users on Panasonic and addling all new users on fusionPBX, usong 2 service providers right now, both providers are registered with Panasonic pbx and want to move one provider to fusion but before doing that I need a full (both direction) communication between both systems. I registered fusion gateway as a panasonic extension and able to make out and in both calls. now did same thing other way so I created and domain on fusion side and create an extension and registered that extension as panasonic SIP trunk. this part is not working, when i try to make out call form that trunk error message on fusion console says
2021-09-07 23:28:09.892506 [INFO] switch_core_state_machine.c:312 No Route, Aborting
i dont know why this call is going to inbound route, it may be because of
2021-09-07 23:32:57.312404 [INFO] mod_dialplan_xml.c:637 Processing my name <my number ->dialed number in context public
same if i call DID on fusion side it doesn't send call to panasonic, I already setup bride as did destination
2021-09-07 23:31:12.512406 [INFO] mod_dptools.c:3643 Originate Failed. Cause: NORMAL_TEMPORARY_FAILURE
i can see call is being routed on bridge
Provider A & B >>>>>>Panasonic<><><><><Fusion PBC <<<<<Provider C
want to move provider B to Fusion but still want to keep couple DID destinations on Panasonic side
I will really appreciate your help I already sped lots of time on this and don't want to role back
I already checked And try to follow instruction on following threds
www.pbxforums.com
www.pbxforums.com
SIP TRUNK WIDTH PANASONIC PBX
Hello from Argentina, greetings to all. I have been working in telephony and telecommunications for 25 years. For 6 years in IP telephony. Having implemented several solutions in telephony, from paid systems to free ones. I just joined FUSIONPBX, implementing it on a national Cloud Server. Works...
customer sip trunking
Hello, We have a multitenant setup for hosted phones and it works great. Now we have a customer that has an onsite PBX and needs a SIP trunk from us. Does FusionPBX support this? And if so how can I implement it I would need a pilot number for the customer to register their trunk to, and...
