Fusionpbx on Raspberry PI
EGL
Hi all,
New here but needs urgent assistance. i have just installed the fusionpbx on my raspberry pi but cannot seem to be able to access the pbx. i get an error message when i enter the IP address on my browser (Error 502, Bad Gateway). Does anyone know what the issue is? this is the 2nd time i am installing it on the same PI.
Can i be able to access my GUI offline (without the internet) on the same pi?
520
At one time I maintained the packages for ARM but without even mentioning it to me they removed my repo from the install script so I haven't been keeping up to date on the state of it. Its likely an nginx/php issue but you would be better off mentioning it in the the fusionpbx channel on freenode IRC. I have plenty of ARM devices to test on but unfortunately I am away until next week.
EGL
Thanks a lot. i will try to reach out to them. I am new on this. this is my 1st attempt to install fusionpbx
EasyBB
240
33
Australia
Did you install from packages or compiled from source?
It would be easier to install Fusion in a VM (virtualbox or vmware) and test that way.
EGL
Thanks for your reply
i got the script from the fusionpbx site.
Could it be that it doesn't work well with Raspbian OS. i will try to install Debian jessie on VM and try that.
520
Pi will work fine, Pi2 or above anyway for a small install. I'm back at home now, I will spin one up today.
520
I had a look at this yesterday and things don't look so good anymore.
I'm using the new Pi 3 and this only seems to work with stretch. Unfortunately there are no packages for stretch and I cannot seem to get them to build due to the way the build scripts have jessie hardcoded in places.
EGL
so the best thing to do is to get older Pi if i must install fusionpbx on Pi right?
520
I would just hang fire or not use a Pi at all, there is much better.
520
@krooney There are many ways. I will write a simple cluster tutorial very soon. In the meantime I would hang fire a touch, freeswitch say there will be stretch packages for the end of the week for fs 1.8. If thats the case I should be able to build them.
Do you really want to cluster on a PI?
Just IMHO there are much better boards, Rock64 for example.
krooney
149
15
Thanks for the quick response i will wait for your simple cluster
agree
73
Can someone please write a script for installing fusionpbx on raspberry pi 3+. I spent hours in trying, but the default fusion install scripts fails. I managed to get fusion installed and pass through most of the errors but the switch.sh script fails with a lot of errors, anyone succeeded please provide the steps. the default scripts fails with packages unmet dependencies. I tried to install from source I had fewer errors but still a lot of errors no repo for armhf.
520
The current freeswitch build for Debian still fails on stretch, we will need to wait for freeswitch to update the build.
