FusionPBX to GPT4
Adrian Last
Connect Fusionbpx to Chat GPT4
Prerequisites
  1. https://platform.openai.com/account Signup for an account and assign it to the api_key variable
  2. https://azure.microsoft.com/en-us/free/cognitive-services and assign it to the SPEECH_KEY variable
  3. The following lua packages installed using lua-rocks (luasocket, cjson)
  4. json file attached. I think cjson will work too but I had some issues. Place this file in the lua5.x directory
  5. Enable mod_flite https://developer.signalwire.com/freeswitch/FreeSWITCH-Explained/Modules/mod_flite_3965160/ -This is just to test. You can use Azure Text to Speech instead of mod_flite.
  6. Upload the switchgpt.lua files to /usr/share/freeswitch/scripts
  7. Setup a dialplan in Fusionpbx that will run the lua application
How does it work?
Place a call to the number assigned in the dialplan that's tied to the lua application and ask your question.
  • json.lua
  • switchgpt.lua
Adrian Last
Remember to uncomment this line
session:speak("Welcome to the ChatGPT phone service. To ask a question, speak clearly after the beep, then press #") -- TESTING
Adrian Last
I could write a function to use Amazon pollytts
or
I could write a function to use pico which will generate the audio files locally
whut
191
This looks interesting. I have been playing with chatgpt and other AI for a few weeks now and have been thinking of ways to use in fusionpbx. In my testing I discovered, no surprise, that gpu processing is so much faster than cpu processing. cpu processing is not going to be viable as it takes much too long.
Adrian Last
Using Microsoft TTS or Voice RSS is actually fast. Currently working on using GPT to automatically answer osticket user questions to reset passwords, suggest level 1 trouble shooting steps over the phone. The text-to-speech processes very fast only a slight slow response from openai gpt API.
whut
191
Oh yes. I am interested in integrating with OS tickets. Potentially very useful functionality!
Adrian Last
It's scary accurate on ticket responses, a little too scary. I will post the finish Lua code when debugging is completed for you to test it.
whut
191
Awesome! Yes it can be scary how " smart " The AI is, but that shows what time is it how powerful it is, and should be all the better for your needs.
I should have stated earlier that the heavy processing was using their whisper AI to transcribe audio and video files.
