Gateway not starting in FusionPBX
destrokal
When I connect freeswitch using fs_cli, I can't see any gateway configured there. Command "sofia status gateway" showing 0 gateways configured. Any advice/suggestion will be highly appreciated.
I've read this post but I also have the hostname empty and still is not working for me.
Any idea what could be causing this.
566
A log from the cli would be better when you try and start the gateway.
kiran870
13
any solution for this below are the logs
2019-12-06 16:19:52.543213 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
2019-12-06 16:19:52.543213 [ERR] mod_sofia.c:4702 Invalid Gateway '97cc0201-685d-43ff-8289-5cbe5a34b155'
2019-12-06 16:19:52.543213 [NOTICE] mod_sofia.c:5117 Close Channel N/A [CS_NEW]
2019-12-06 16:19:52.543213 [DEBUG] switch_core_state_machine.c:738 () Running State Change CS_DESTROY (Cur 1 Tot 29)
2019-12-06 16:19:52.543213 [DEBUG] switch_core_state_machine.c:748 (N/A) State DESTROY
2019-12-06 16:19:52.543213 [DEBUG] mod_sofia.c:354 N/A SOFIA DESTROY
2019-12-06 16:19:52.543213 [DEBUG] switch_core_state_machine.c:748 (N/A) State DESTROY going to sleep
2019-12-06 16:19:52.543213 [NOTICE] switch_ivr_originate.c:2944 Cannot create outgoing channel of type [sofia] cause: [INVALID_GATEWAY]
2019-12-06 16:19:52.543213 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 608 [INVALID_GATEWAY]
2019-12-06 16:19:52.543213 [INFO] mod_dptools.c:3518 Originate Failed. Cause: INVALID_GATEWAY
mak_make
52
I am using fusionpbx 4.5.28 and the gateway not starting. Below is the FS Log:
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-version [tlsv1,tlsv1.1,tlsv1.2]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 sip-capture [no]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 rfc2833-pt [101]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 sip-port [5080]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 dialplan [XML]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 track-calls [false]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 context [public]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 dtmf-type [rfc2833]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 dtmf-duration [2000]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 inbound-codec-prefs [G7221@32000h,G7221@16000h,G722,PCMU,PCMA]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 outbound-codec-prefs [PCMU,PCMA]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 hold-music [local_stream://default]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 zrtp-passthru [true]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 rtp-timer-name [soft]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 manage-presence [false]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 local-network-acl [localnet.auto]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 apply-nat-acl [nat.auto]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 apply-inbound-acl [domains]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 suppress-cng [true]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 inbound-codec-negotiation [generous]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 nonce-ttl [60]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 auth-calls [true]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 auth-subscriptions [true]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 rtp-ip [192.99.75.3]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 sip-ip [192.99.75.3]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 ext-rtp-ip [192.99.75.3]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 ext-sip-ip [192.99.75.3]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 rtp-timeout-sec [300]
2021-11-26 09:42:25.892773 [WARNING] sofia.c:5302 rtp-timeout-sec deprecated use media_timeout variable.
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 rtp-hold-timeout-sec [1800]
2021-11-26 09:42:25.892773 [WARNING] sofia.c:5309 rtp-hold-timeout-sec deprecated use media_hold_timeout variable.
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls [false]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-only [false]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-bind-params [transport=tls]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-sip-port [5081]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-cert-dir [/etc/freeswitch/tls]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-passphrase []
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-verify-date [false]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-verify-depth [2]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 tls-verify-in-subjects []
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 debug [0]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 user-agent-string [FreeSWITCH]
2021-11-26 09:42:25.892773 [DEBUG] sofia.c:4703 sip-trace [no]
2021-11-26 09:42:25.892773 [INFO] sofia.c:6103 Setting MAX Auth Validity to 0 Attempts
Any Idea how to solve this
