Leaving Voicemail from PSTN, No BEEP sound
gflow
271
31
Hi Guys,
When I leave a voicemail on a phone extension to extension I hear the greeting and then the beep to leave a message. However if I call from my mobile phone I hear the greeting but no beep, I can still leave a voicemail which is received successfully but I really need a beep to play or i'll start getting some complaints. Below is part of the debug and I see it says "done playing file tone_stream" for the beep but I never actually hear that sound. I have tried changing the tone to the same as the conference room tone (which I can hear from from my mobile) but even that doesnt play. I running Fusion 4.4.9. Any assistance would be great.
2020-01-15 16:20:22.512588 [DEBUG] switch_ivr_play_say.c:1497 Codec Activated L16@8000hz 1 channels 20ms
2020-01-15 16:20:27.132548 [DEBUG] switch_ivr_play_say.c:1941 done playing file /var/lib/freeswitch/storage/voicemail/default/domain/3000/greeting_1.wav
2020-01-15 16:20:27.232585 [DEBUG] switch_ivr_play_say.c:1497 Codec Activated L16@8000hz 1 channels 20ms
2020-01-15 16:20:30.952543 [DEBUG] switch_cpp.cpp:1443 [presence] turn_lamp: *30@domain.com - false(boolean)
2020-01-15 16:20:31.832557 [DEBUG] switch_ivr_play_say.c:1941 done playing file /usr/share/freeswitch/sounds/en/us/callie/voicemail/vm-record_message.wav
2020-01-15 16:20:31.952550 [DEBUG] switch_cpp.cpp:905 getDigits dtmf_buf:
2020-01-15 16:20:32.952553 [DEBUG] switch_cpp.cpp:905 getDigits dtmf_buf:
2020-01-15 16:20:32.952553 [DEBUG] switch_ivr_play_say.c:1497 Codec Activated L16@8000hz 1 channels 20ms
2020-01-15 16:20:33.952621 [DEBUG] switch_ivr_play_say.c:1941 done playing file tone_stream://L=1;%(1000, 0, 640)
2020-01-15 16:20:34.072563 [DEBUG] switch_cpp.cpp:905 getDigits dtmf_buf:
2020-01-15 16:20:34.072563 [DEBUG] switch_ivr_play_say.c:567 Raw Codec Activated, ready to waste resources!
2020-01-15 16:20:34.072563 [DEBUG] switch_ivr_play_say.c:681 Raw Codec Activated
Can anybody else confirm if they have the same issue? Just call in from a mobile phone and let me know if you hear the beep before you start to leave your message.
I am having this issue, I am only having this issue on one of my domains. The rest are working fine.
