Limit Max extension setting not working
rasimoes
15
How this settings is supposed to work?
For example: I've set the limit max to 1, but still can make 2 or more outgoing calls at the same time. I think this setting should deny more than 1 concurrent outgoing call, right?
max is the amount of ext your allowed to make. you need to limit outbound calls
I'll explain with more details: I'm be creating an extension, where a customer will be using it as a SIP trunk; So, I need a way to limit the maximum concurrent calls when it using that trunk.
I've tried to limit using the 'limit max' setting, but no success. Any clues?
