tport.c:2770 tport_wakeup_pri() tport_wakeup_pri(0x7f1048004e90): events IN
tport.c:2893 tport_recv_event() tport_recv_event(0x7f1048004e90)
tport.c:3234 tport_recv_iovec() tport_recv_iovec(0x7f1048004e90) msg 0x7f1048041b60 from (udp/192.168.1.154:5060) has 2 bytes, veclen = 1
tport.c:3052 tport_deliver() tport_deliver(0x7f1048004e90): bad msg 0x7f1048041b60 (2 bytes) from udp/192.168.1.1:5060/sip next=(nil)
2021-04-20 11:49:46.801622 [DEBUG] switch_ivr_originate.c:2242 Parsing global variables
2021-04-20 11:49:46.801622 [NOTICE] switch_channel.c:1118 New Channel sofia/external/+150XXXXXXXX [4c7b587d-ce16-4137-9841-dbe6aa7a8dba]
2021-04-20 11:49:46.801622 [DEBUG] mod_sofia.c:5089 (sofia/external/+150XXXXXXXX) State Change CS_NEW -> CS_INIT
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:585 (sofia/external/+150XXXXXXXX) Running State Change CS_INIT (Cur 1 Tot 87)
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:628 (sofia/external/+150XXXXXXXX) State INIT
2021-04-20 11:49:46.801622 [DEBUG] mod_sofia.c:93 sofia/external/+150XXXXXXXX SOFIA INIT
nua_common.c:108 nh_create_handle() nua: nh_create_handle: entering
nua.c:346 nua_handle_bind() nua: nua_handle_bind: entering
2021-04-20 11:49:46.801622 [DEBUG] sofia_glue.c:1618 sofia/external/+150XXXXXXXX sending invite version: 1.10.5 -release-17-25569c1631 64bit
Local SDP:
v=0
o=FreeSWITCH 1618918270 1618918271 IN IP4 70.50.150.80
s=FreeSWITCH
c=IN IP4 70.50.150.80
t=0 0
m=audio 26316 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
nua.c:637 nua_invite() nua: nua_invite: entering
nua_stack.c:529 nua_signal() nua(0x7f10540259c0): sent signal r_invite
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:40 sofia/external/+150XXXXXXXX Standard INIT
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:48 (sofia/external/+150XXXXXXXX) State Change CS_INIT -> CS_ROUTING
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:628 (sofia/external/+150XXXXXXXX) State INIT going to sleep
nua_stack.c:569 nua_stack_signal() nua(0x7f10540259c0): recv signal r_invite
nua_params.c:484 nua_stack_set_params() nua: nua_stack_set_params: entering
soa.c:280 soa_clone() soa_clone(static::0x7f1054001b90, 0x7f1054001390, 0x7f10540259c0) called
soa.c:403 soa_set_params() soa_set_params(static::0x7f1054069170, ...) called
soa.c:1052 soa_set_user_sdp() soa_set_user_sdp(static::0x7f1054069170, (nil), 0x7f105404783b, -1) called
soa.c:890 soa_set_capability_sdp() soa_set_capability_sdp(static::0x7f1054069170, (nil), 0x7f105404783b, -1) called
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:585 (sofia/external/+150XXXXXXXX) Running State Change CS_ROUTING (Cur 1 Tot 87)
nua_dialog.c:338 nua_dialog_usage_add() nua(0x7f10540259c0): adding session usage
nta.c:4446 nta_leg_tcreate() nta_leg_tcreate(0x7f1054019a80)
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:644 (sofia/external/+150XXXXXXXX) State ROUTING
soa.c:1302 soa_init_offer_answer() soa_init_offer_answer(static::0x7f1054069170) called
soa.c:1426 soa_generate_offer() soa_generate_offer(static::0x7f1054069170, 0) called
2021-04-20 11:49:46.801622 [DEBUG] mod_sofia.c:154 sofia/external/+150XXXXXXXX SOFIA ROUTING
2021-04-20 11:49:46.801622 [DEBUG] switch_ivr_originate.c:67 (sofia/external/+150XXXXXXXX) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:644 (sofia/external/+150XXXXXXXX) State ROUTING going to sleep
soa_static.c:1148 offer_answer_step() soa_static_offer_answer_action(0x7f1054069170, soa_generate_offer): called
soa_static.c:1189 offer_answer_step() soa_static(0x7f1054069170, soa_generate_offer): generating local description
soa_static.c:1217 offer_answer_step() soa_static(0x7f1054069170, soa_generate_offer): upgrade with local description
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:585 (sofia/external/+150XXXXXXXX) Running State Change CS_CONSUME_MEDIA (Cur 1 Tot 87)
soa_static.c:1029 soa_sdp_mode_set() soa_sdp_mode_set(0x7f107d626820, (nil), ""): called
soa_static.c:1446 offer_answer_step() soa_static(0x7f1054069170, soa_generate_offer): storing local description
soa.c:1270 soa_get_local_sdp() soa_get_local_sdp(static::0x7f1054069170, [(nil)], [0x7f107d6289a0], [0x7f107d62899c]) called
nta.c:2694 nta_tpn_by_url() nta: selecting scheme sip
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:663 (sofia/external/+150XXXXXXXX) State CONSUME_MEDIA
sres_cache.c:272 sres_cache_get() sres_cache_get(0x7f10540044b0, SRV, "_sips._tcp.pbx.pstn.twilio.com.") called
2021-04-20 11:49:46.801622 [DEBUG] switch_core_state_machine.c:663 (sofia/external/+150XXXXXXXX) State CONSUME_MEDIA going to sleep
nta.c:10683 outgoing_query_srv() nta: for "pbx.pstn.twilio.com" query "_sips._tcp.pbx.pstn.twilio.com" SRV
sres.c:968 sres_query() sres_query(0x7f10540041d0, 0x7f1054046d00, SRV, "_sips._tcp.pbx.pstn.twilio.com") called
sres.c:2731 sres_send_dns_query() sres_send_dns_query(0x7f10540041d0, 0x7f1054065810) called
sres.c:2820 sres_send_dns_query() sres_send_dns_query(0x7f10540041d0, 0x7f1054065810) id=25929 SRV _sips._tcp.pbx.pstn.twilio.com (to [192.168.1.1]:53)
nua_session.c:4140 signal_call_state_change() nua(0x7f10540259c0): call state changed: init -> calling, sent offer
soa.c:1270 soa_get_local_sdp() soa_get_local_sdp(static::0x7f1054069170, [0x7f107d628980], [0x7f107d628988], [(nil)]) called
nua_stack.c:269 nua_stack_event() nua(0x7f10540259c0): event i_state INVITE sent
nua_stack.c:359 nua_application_event() nua: nua_application_event: entering
nua.c:370 nua_handle_magic() nua: nua_handle_magic: entering
2021-04-20 11:49:46.801622 [DEBUG] sofia.c:7326 Channel sofia/external/+150XXXXXXXX entering state [calling][0]
sres.c:3468 sres_resolver_receive() sres_resolver_receive(0x7f10540041d0, 84) called
sres.c:3782 sres_create_record() AUTHORITY RR received twilio.com. SOA IN 180 rdlen=44
sres.c:3573 sres_log_response() sres_resolver_receive(0x7f10540041d0, 0x7f1054065810) id=25929 (from [192.168.1.1]:53)
sres.c:2988 sres_query_report_error() sres(q=0x7f1054065810): reporting error RECORD_ERR for SRV _sips._tcp.pbx.pstn.twilio.com
sres_cache.c:272 sres_cache_get() sres_cache_get(0x7f10540044b0, A, "pbx.pstn.twilio.com.") called
nta.c:10891 outgoing_query_a() nta: for "pbx.pstn.twilio.com" query "pbx.pstn.twilio.com" A
sres.c:968 sres_query() sres_query(0x7f10540041d0, 0x7f1054046d00, A, "pbx.pstn.twilio.com") called
sres.c:2731 sres_send_dns_query() sres_send_dns_query(0x7f10540041d0, 0x7f10540b2870) called
sres.c:2820 sres_send_dns_query() sres_send_dns_query(0x7f10540041d0, 0x7f10540b2870) id=25930 A pbx.pstn.twilio.com (to [192.168.1.1]:53)
sres.c:3782 sres_create_record() ANSWER RR received pbx.pstn.twilio.com. A IN 600 rdlen=4
sres.c:3573 sres_log_response() sres_resolver_receive(0x7f10540041d0, 0x7f10540b2870) id=25930 (from [192.168.1.1]:53)
nta.c:10944 outgoing_answer_a() nta: pbx.pstn.twilio.com. IN A 54.172.60.0
nta.c:10946 outgoing_answer_a() nta(0x7f1054046d00): A 54.172.60.1
nta.c:10946 outgoing_answer_a() nta(0x7f1054046d00): A 54.172.60.2
nta.c:10946 outgoing_answer_a() nta(0x7f1054046d00): A 54.172.60.3
tport.c:3286 tport_tsend() tport_tsend(0x7f1054006d10) tpn = tls/54.172.60.0:5061
tport.c:4075 tport_resolve() tport_resolve addrinfo = 54.172.60.0:5061
tport.c:4709 tport_by_addrinfo() tport_by_addrinfo(0x7f1054006d10): not found by name tls/54.172.60.0:5061
tport.c:862 tport_alloc_secondary() tport_alloc_secondary(0x7f1054006d10): new secondary tport 0x7f105404bd30
tport_type_tcp.c:203 tport_tcp_init_secondary() tport_tcp_init_secondary(0x7f105404bd30): Setting TCP_KEEPIDLE to 30
tport_type_tcp.c:209 tport_tcp_init_secondary() tport_tcp_init_secondary(0x7f105404bd30): Setting TCP_KEEPINTVL to 30
tport_type_tls.c:686 tport_tls_connect() tport_tls_connect(0x7f105404bd30): connecting to tls/54.172.60.0:5061/sips
tport.c:2311 tport_set_secondary_timer() tport(0x7f105404bd30): reset timer
tport.c:3811 tport_queue() tport_queue(0x7f105404bd30): queueing 0x7f1054066cd0 for tls/54.172.60.0:5061
nta.c:8348 outgoing_send() nta: sent INVITE (34918502) to tls/54.172.60.0:5061
tport.c:4189 tport_pend() tport_pend(0x7f105404bd30): pending 0x7f1054066cd0 for tls/54.172.60.0:5061 (already 0)
nta.c:1354 set_timeout() nta: timer set to 32000 ms
tport_tls.c:960 tls_connect() tls_connect(0x7f105404bd30): events CONNECTING
tport_tls.c:960 tls_connect() tls_connect(0x7f105404bd30): events NEGOTIATING
tport_tls.c:603 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): TLS cipher chosen (name): ECDHE-RSA-AES128-GCM-SHA256
tport_tls.c:605 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): TLS cipher chosen (version): TLSv1.2
tport_tls.c:608 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): TLS cipher chosen (bits/alg_bits): 128/128
tport_tls.c:611 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): TLS cipher chosen (description): ECDHE-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(128) Mac=AEAD
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): Peer Certificate Subject 0: *.pstn.twilio.com
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): Peer Certificate Subject 1: *.sip.twilio.com
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): Peer Certificate Subject 2: *.pstn.us1.twilio.com
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f105404bd30): Peer Certificate Subject 3: *.sip.us1.twilio.com
tport.c:3952 tport_send_event() tport_send_event(0x7f105404bd30) - ready to send to (tls/54.172.60.0:5061)
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f1054029410 0x7f105405d5e0 874 (874)
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f1054029410 0x7f1054053e30 271 (271)
tport.c:3623 tport_vsend() tport_vsend(0x7f105404bd30): 1145 bytes of 1145 to tls/54.172.60.0:5061
tport.c:3521 tport_send_msg() tport_vsend returned 1145
send 1145 bytes to tls/[54.172.60.0]:5061 at 11:49:49.408095:
INVITE sip:+150XXXXXXXX@pbx.pstn.twilio.com;transport=tls SIP/2.0
Via: SIP/2.0/TLS 70.50.150.80:5081;rport;branch=z9hG4bKBgHyDm9QK8NyH
Max-Forwards: 70
From: <sip:36XXXXXXXX@70.50.150.80>;tag=yecr2v4K79Brg
To: <sip:+150XXXXXXXX@pbx.pstn.twilio.com>
Call-ID: 0651de59-1cac-123a-ca8b-a41f7259508a
CSeq: 34918502 INVITE
Contact: <sip:gw+f0079869-728a-4d02-8e24-41bed917685a@70.50.150.80:5081;transport=tls;transport=tls;gw=f0079869-728a-4d02-8e24-41bed917685a>
User-Agent: FreeSWITCH
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 271
Remote-Party-ID: <sip:36XXXXXXXX@70.50.150.80>;party=calling;screen=yes;privacy=off
v=0
s=FreeSWITCH
t=0 0
a=fmtp:101 0-16
a=ptime:20
tport_type_tls.c:338 tport_tls_set_events() tport_tls_set_events(0x7f105404bd30): logical events IN real IN
tport.c:2795 tport_wakeup() tport_wakeup(0x7f105404bd30): events IN
tport.c:2893 tport_recv_event() tport_recv_event(0x7f105404bd30)
tport_type_tls.c:434 tport_tls_recv() tport_tls_recv(0x7f105404bd30): tls_read() returned 367
tport.c:3234 tport_recv_iovec() tport_recv_iovec(0x7f105404bd30) msg 0x7f1054048950 from (tls/54.172.60.0:5061) has 367 bytes, veclen = 1
recv 367 bytes from tls/[54.172.60.0]:5061 at 11:49:49.501913:
SIP/2.0 100 trying -- your call is important to us
Via: SIP/2.0/TLS 70.50.150.80:5081;rport=60637;branch=z9hG4bKBgHyDm9QK8NyH;received=70.50.150.80
Server: Twilio Gateway
Content-Length: 0
tport.c:3052 tport_deliver() tport_deliver(0x7f105404bd30): msg 0x7f1054048950 (367 bytes) from tls/54.172.60.0:5061/sips next=(nil)
nta.c:3328 agent_recv_response() nta: received 100 trying -- your call is important to us for INVITE (34918502)
nta.c:3395 agent_recv_response() nta: 100 trying -- your call is important to us is going to a transaction
nta.c:9642 outgoing_estimate_delay() nta_outgoing: RTT is 366.405 ms
tport.c:4251 tport_release() tport_release(0x7f105404bd30): 0x7f1054066cd0 by 0x7f1054046d00 with 0x7f1054048950 (preliminary)
tport_type_tls.c:434 tport_tls_recv() tport_tls_recv(0x7f105404bd30): tls_read() returned 603
tport.c:3234 tport_recv_iovec() tport_recv_iovec(0x7f105404bd30) msg 0x7f1054024ff0 from (tls/54.172.60.0:5061) has 603 bytes, veclen = 1
recv 603 bytes from tls/[54.172.60.0]:5061 at 11:49:49.510719:
SIP/2.0 407 Proxy Authentication required
To: <sip:+150XXXXXXXX@pbx.pstn.twilio.com>;tag=36445672_6772d868_d6dde871-19bd-4d08-9a9f-5ab87e65e20e
Via: SIP/2.0/TLS 70.50.150.80:5081;received=70.50.150.80;rport=60637;branch=z9hG4bKBgHyDm9QK8NyH
Server: Twilio
Contact: <sip:172.25.80.6:5060>
Proxy-Authenticate: Digest realm="sip.twilio.com",qop="auth",nonce="hhjbzv19RkLruSlgYhI-S4fmG69Y8OA1HqIykPVCnXxsRSbx",opaque="782c8f33f68f63a535910c20cbd8baef"
Content-Length: 0
tport.c:3052 tport_deliver() tport_deliver(0x7f105404bd30): msg 0x7f1054024ff0 (603 bytes) from tls/54.172.60.0:5061/sips next=(nil)
nta.c:3328 agent_recv_response() nta: received 407 Proxy Authentication required for INVITE (34918502)
nta.c:3395 agent_recv_response() nta: 407 Proxy Authentication required is going to a transaction
tport.c:4251 tport_release() tport_release(0x7f105404bd30): 0x7f1054066cd0 by 0x7f1054046d00 with 0x7f1054024ff0
tport.c:4617 tport_by_name() tport(0x7f1054006d10): found 0x7f105404bd30 by name tls/54.172.60.0:5061
tport.c:3286 tport_tsend() tport_tsend(0x7f105404bd30) tpn = tls/54.172.60.0:5061
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f1054029410 0x7f105404aff0 404 (404)
tport.c:3623 tport_vsend() tport_vsend(0x7f105404bd30): 404 bytes of 404 to tls/54.172.60.0:5061
tport.c:3521 tport_send_msg() tport_vsend returned 404
send 404 bytes to tls/[54.172.60.0]:5061 at 11:49:49.510835:
ACK sip:+150XXXXXXXX@pbx.pstn.twilio.com;transport=tls SIP/2.0
Max-Forwards: 70
CSeq: 34918502 ACK
Content-Length: 0
nta.c:8348 outgoing_send() nta: sent ACK (34918502) to tls/54.172.60.0:5061
nta.c:8774 outgoing_free() nta: outgoing_free(0x7f1054046980)
auth_digest.c:105 auth_digest_challenge_get() auth_digest_challenge_get(): got 5
nua_stack.c:271 nua_stack_event() nua(0x7f10540259c0): event r_invite 407 Proxy Authentication required
nua.c:838 nua_authenticate() nua: nua_authenticate: entering
nua_stack.c:569 nua_stack_signal() nua(0x7f10540259c0): recv signal r_authenticate
nua_stack.c:529 nua_signal() nua(0x7f10540259c0): sent signal r_authenticate
soa_static.c:1029 soa_sdp_mode_set() soa_sdp_mode_set(0x7f10380076a0, (nil), ""): called
soa.c:1270 soa_get_local_sdp() soa_get_local_sdp(static::0x7f1054069170, [(nil)], [0x7f107d6289e0], [0x7f107d6289dc]) called
auth_digest.c:226 auth_digest_a1() auth_digest_a1() has A1 = MD5(authUser:sip.twilio.com:pass) = c7a8d2e983c8cba15f50a83463d9106a
auth_digest.c:318 auth_digest_response() A2 = MD5(INVITE:sip:+150XXXXXXXX@pbx.pstn.twilio.com;transport=tls)
auth_digest.c:348 auth_digest_response() auth_response: 66a58ddcdb377df9196f0ac44d407c5a = MD5(c7a8d2e983c8cba15f50a83463d9106a:hhjbzv19RkLruSlgYhI-S4fmG69Y8OA1HqIykPVCnXxsRSbx:00000001:Bo+61RysEjqLyqQfcllQig:auth:ae4172f103f8b421e4cf875140333c91) (qop=auth)
sres_cache.c:318 sres_cache_get() sres_cache_get(0x7f10540044b0, SRV, "_sips._tcp.pbx.pstn.twilio.com.") returned 1 entries
nta.c:10683 outgoing_query_srv() nta: for "pbx.pstn.twilio.com" query "_sips._tcp.pbx.pstn.twilio.com" SRV (cached)
sres_cache.c:318 sres_cache_get() sres_cache_get(0x7f10540044b0, A, "pbx.pstn.twilio.com.") returned 4 entries
nta.c:10891 outgoing_query_a() nta: for "pbx.pstn.twilio.com" query "pbx.pstn.twilio.com" A (cached)
nta.c:10944 outgoing_answer_a() nta: pbx.pstn.twilio.com. IN A 54.172.60.1
nta.c:10946 outgoing_answer_a() nta(0x7f1054029650): A 54.172.60.2
nta.c:10946 outgoing_answer_a() nta(0x7f1054029650): A 54.172.60.3
nta.c:10946 outgoing_answer_a() nta(0x7f1054029650): A 54.172.60.0
tport.c:3286 tport_tsend() tport_tsend(0x7f1054006d10) tpn = tls/54.172.60.1:5061
tport.c:4075 tport_resolve() tport_resolve addrinfo = 54.172.60.1:5061
tport.c:4709 tport_by_addrinfo() tport_by_addrinfo(0x7f1054006d10): not found by name tls/54.172.60.1:5061
tport.c:862 tport_alloc_secondary() tport_alloc_secondary(0x7f1054006d10): new secondary tport 0x7f10540388a0
tport_type_tcp.c:203 tport_tcp_init_secondary() tport_tcp_init_secondary(0x7f10540388a0): Setting TCP_KEEPIDLE to 30
tport_type_tcp.c:209 tport_tcp_init_secondary() tport_tcp_init_secondary(0x7f10540388a0): Setting TCP_KEEPINTVL to 30
tport_type_tls.c:686 tport_tls_connect() tport_tls_connect(0x7f10540388a0): connecting to tls/54.172.60.1:5061/sips
tport.c:2311 tport_set_secondary_timer() tport(0x7f10540388a0): reset timer
tport.c:3811 tport_queue() tport_queue(0x7f10540388a0): queueing 0x7f1054048950 for tls/54.172.60.1:5061
nta.c:8348 outgoing_send() nta: sent INVITE (34918503) to tls/54.172.60.1:5061
tport.c:4189 tport_pend() tport_pend(0x7f10540388a0): pending 0x7f1054048950 for tls/54.172.60.1:5061 (already 0)
nua_session.c:4140 signal_call_state_change() nua(0x7f10540259c0): call state changed: calling -> calling, sent offer
soa.c:1270 soa_get_local_sdp() soa_get_local_sdp(static::0x7f1054069170, [0x7f107d6289c0], [0x7f107d6289c8], [(nil)]) called
2021-04-20 11:49:47.221614 [DEBUG] sofia.c:7326 Channel sofia/external/+150XXXXXXXX entering state [calling][0]
tport_tls.c:960 tls_connect() tls_connect(0x7f10540388a0): events CONNECTING
tport_tls.c:960 tls_connect() tls_connect(0x7f10540388a0): events NEGOTIATING
tport_tls.c:603 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): TLS cipher chosen (name): ECDHE-RSA-AES128-GCM-SHA256
tport_tls.c:605 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): TLS cipher chosen (version): TLSv1.2
tport_tls.c:608 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): TLS cipher chosen (bits/alg_bits): 128/128
tport_tls.c:611 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): TLS cipher chosen (description): ECDHE-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(128) Mac=AEAD
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): Peer Certificate Subject 0: *.pstn.twilio.com
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): Peer Certificate Subject 1: *.sip.twilio.com
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): Peer Certificate Subject 2: *.pstn.us1.twilio.com
tport_tls.c:698 tls_post_connection_check() tls_post_connection_check(0x7f10540388a0): Peer Certificate Subject 3: *.sip.us1.twilio.com
tport.c:3952 tport_send_event() tport_send_event(0x7f10540388a0) - ready to send to (tls/54.172.60.1:5061)
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f10540327e0 0x7f105404aff0 1016 (1016)
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f10540327e0 0x7f105401eaf0 209 (209)
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f10540327e0 0x7f105401c250 271 (271)
tport.c:3623 tport_vsend() tport_vsend(0x7f10540388a0): 1496 bytes of 1496 to tls/54.172.60.1:5061
tport.c:3521 tport_send_msg() tport_vsend returned 1496
send 1496 bytes to tls/[54.172.60.1]:5061 at 11:49:49.791459:
Via: SIP/2.0/TLS 70.50.150.80:5081;rport;branch=z9hG4bKcSaQFFtUgHcHD
Max-Forwards: 70
CSeq: 34918503 INVITE
Proxy-Authorization: Digest username="authUser", realm="sip.twilio.com", nonce="hhjbzv19RkLruSlgYhI-S4fmG69Y8OA1HqIykPVCnXxsRSbx", cnonce="Bo+61RysEjqLyqQfcllQig", opaque="782c8f33f68f63a535910c20cbd8baef", algorithm=MD5, uri="sip:+150XXXXXXXX@pbx.pstn.twilio.com;transport=tls", response="66a58ddcdb377df9196f0ac44d407c5a", qop=auth, nc=00000001
Content-Length: 271
v=0
s=FreeSWITCH
t=0 0
a=fmtp:101 0-16
a=ptime:20
tport_type_tls.c:338 tport_tls_set_events() tport_tls_set_events(0x7f10540388a0): logical events IN real IN
tport.c:2795 tport_wakeup() tport_wakeup(0x7f10540388a0): events IN
tport.c:2893 tport_recv_event() tport_recv_event(0x7f10540388a0)
tport_type_tls.c:434 tport_tls_recv() tport_tls_recv(0x7f10540388a0): tls_read() returned 367
tport.c:3234 tport_recv_iovec() tport_recv_iovec(0x7f10540388a0) msg 0x7f1054027460 from (tls/54.172.60.1:5061) has 367 bytes, veclen = 1
recv 367 bytes from tls/[54.172.60.1]:5061 at 11:49:49.883358:
Via: SIP/2.0/TLS 70.50.150.80:5081;rport=41995;branch=z9hG4bKcSaQFFtUgHcHD;received=70.50.150.80
Content-Length: 0
tport.c:3052 tport_deliver() tport_deliver(0x7f10540388a0): msg 0x7f1054027460 (367 bytes) from tls/54.172.60.1:5061/sips next=(nil)
nta.c:3328 agent_recv_response() nta: received 100 trying -- your call is important to us for INVITE (34918503)
nta.c:9642 outgoing_estimate_delay() nta_outgoing: RTT is 372.104 ms
tport.c:4251 tport_release() tport_release(0x7f10540388a0): 0x7f1054048950 by 0x7f1054029650 with 0x7f1054027460 (preliminary)
tport_type_tls.c:434 tport_tls_recv() tport_tls_recv(0x7f10540388a0): tls_read() returned 518
tport.c:3234 tport_recv_iovec() tport_recv_iovec(0x7f10540388a0) msg 0x7f1054069650 from (tls/54.172.60.1:5061) has 518 bytes, veclen = 1
recv 518 bytes from tls/[54.172.60.1]:5061 at 11:49:49.898930:
SIP/2.0 488 Secure media required
To: <sip:+150XXXXXXXX@pbx.pstn.twilio.com>;tag=02555165_6772d868_3ba09843-8937-4126-8da0-a0f6432ab7ec
Via: SIP/2.0/TLS 70.50.150.80:5081;received=70.50.150.80;rport=41995;branch=z9hG4bKcSaQFFtUgHcHD
Server: Twilio
Contact: <sip:172.25.72.90:5060>
X-Twilio-Error: 32208 SIP trunk or domain is required to use secure media (SRTP).
Content-Length: 0
tport.c:3052 tport_deliver() tport_deliver(0x7f10540388a0): msg 0x7f1054069650 (518 bytes) from tls/54.172.60.1:5061/sips next=(nil)
nta.c:3328 agent_recv_response() nta: received 488 Secure media required for INVITE (34918503)
nta.c:3395 agent_recv_response() nta: 488 Secure media required is going to a transaction
tport.c:4251 tport_release() tport_release(0x7f10540388a0): 0x7f1054048950 by 0x7f1054029650 with 0x7f1054069650
tport.c:4617 tport_by_name() tport(0x7f1054006d10): found 0x7f10540388a0 by name tls/54.172.60.1:5061
tport.c:3286 tport_tsend() tport_tsend(0x7f10540388a0) tpn = tls/54.172.60.1:5061
tport_type_tls.c:537 tport_tls_send() tport_tls_writevec: vec 0x7f10540327e0 0x7f1054075090 404 (404)
tport.c:3623 tport_vsend() tport_vsend(0x7f10540388a0): 404 bytes of 404 to tls/54.172.60.1:5061
send 404 bytes to tls/[54.172.60.1]:5061 at 11:49:49.899040:
Max-Forwards: 70
CSeq: 34918503 ACK
Content-Length: 0
nta.c:8348 outgoing_send() nta: sent ACK (34918503) to tls/54.172.60.1:5061
nta.c:8774 outgoing_free() nta: outgoing_free(0x7f1054055910)
nua_stack.c:271 nua_stack_event() nua(0x7f10540259c0): event r_invite 488 Secure media required
nua_session.c:4140 signal_call_state_change() nua(0x7f10540259c0): call state changed: calling -> init
nua_stack.c:271 nua_stack_event() nua(0x7f10540259c0): event i_state 488 Secure media required
nua_stack.c:271 nua_stack_event() nua(0x7f10540259c0): event i_terminated 488 Secure media required
nua_dialog.c:397 nua_dialog_usage_remove_at() nua(0x7f10540259c0): removing session usage
soa.c:356 soa_destroy() soa_destroy(static::0x7f1054069170) called
nta.c:4499 nta_leg_destroy() nta_leg_destroy(0x7f1054019a80)
2021-04-20 11:49:47.601614 [DEBUG] sofia.c:7326 Channel sofia/external/+150XXXXXXXX entering state [terminated][488]
2021-04-20 11:49:47.601614 [NOTICE] sofia.c:8559 Hangup sofia/external/+150XXXXXXXX [CS_CONSUME_MEDIA] [INCOMPATIBLE_DESTINATION]
nua.c:925 nua_handle_destroy() nua: nua_handle_destroy: entering
nua_stack.c:529 nua_signal() nua(0x7f10540259c0): sent signal r_destroy
nua_stack.c:569 nua_stack_signal() nua(0x7f10540259c0): recv signal r_destroy
nta.c:4499 nta_leg_destroy() nta_leg_destroy((nil))
2021-04-20 11:49:47.601614 [DEBUG] switch_core_state_machine.c:585 (sofia/external/+150XXXXXXXX) Running State Change CS_HANGUP (Cur 1 Tot 87)
2021-04-20 11:49:47.601614 [DEBUG] switch_core_state_machine.c:848 (sofia/external/+150XXXXXXXX) Callstate Change DOWN -> HANGUP
2021-04-20 11:49:47.601614 [DEBUG] switch_core_state_machine.c:850 (sofia/external/+150XXXXXXXX) State HANGUP
2021-04-20 11:49:47.601614 [DEBUG] mod_sofia.c:453 Channel sofia/external/+150XXXXXXXX hanging up, cause: INCOMPATIBLE_DESTINATION
2021-04-20 11:49:47.601614 [DEBUG] switch_core_state_machine.c:60 sofia/external/+150XXXXXXXX Standard HANGUP, cause: INCOMPATIBLE_DESTINATION
2021-04-20 11:49:47.601614 [DEBUG] switch_core_state_machine.c:850 (sofia/external/+150XXXXXXXX) State HANGUP going to sleep
2021-04-20 11:49:47.601614 [DEBUG] switch_ivr_originate.c:3995 Originate Resulted in Error Cause: 88 [INCOMPATIBLE_DESTINATION]
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] Success: '0'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_result_text: 'FS_NOT_SET'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_file: '/var/lib/freeswitch/storage/fax/MainDomain/700/temp/cad3c8c5-4f80-4837-aba5-6ff1fe6310b1.tif'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] uuid: '4c7b587d-ce16-4137-9841-dbe6aa7a8dba'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_retry_attempts: 1
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_retry_limit: 20
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_retry_sleep: 30
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_uri: 'sofia/gateway/f0079869-728a-4d02-8e24-41bed917685a/+150XXXXXXXX'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] accountcode: 'MainDomain'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] origination_caller_id_name: 000000000000000
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] origination_caller_id_number: 36XXXXXXXX
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] fax_result_code: 2
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] mailfrom_address: wouldyukindly@gmail.com
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] mailto_address: wouldyukindly@gmail.com
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] hangup_cause_q850: '88'
2021-04-20 11:49:47.641637 [INFO] switch_cpp.cpp:1447 [FAX] Last Fax Failed, try a different way. Wait first.
